MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,142
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Basically Moss, compression reads just pressure on it's gauge and just begins to tell the story. Sort of reading the book flap to get the gist of the book. A leak down reads percent of leakage. Leak down is more for chasing down where the leak is as air is fed into the gauge adapter and seeing where it exits. If air is coming out the PCV valve for instance, you have a bad piston ring. Coming out of other areas describes if you have a cylinder head or valve leak etc.. Both gauges are inserted into the empty spark plug hole. The only thing that the compression gauge reads is what is being created by the piston. The leak down gauge is fed air or sometimes nitrogen. It is zeroed and then air is blown in which is then dispersed within the engine cylinder to measure first a leakage percentage and then where the leak is as the air attempts to find the least resistive path for exiting.
Thanks!
