PT-425 PROS & cons??
/ PT-425 PROS & cons?? #301
Re: PT-425 PROS & cons??
Glad to hear you are doing bettery. At my age, 90% or better is the best I can hope for.
Could we get pictures of the changed battery box? Did you use a different battery?
/ PT-425 PROS & cons?? #302
FOURTEEN said:
I'm back!!!
Long hot summer!
Too hot to work in the woods!
Too dry, (worse drought in NC history), to burn!
New battery. Had to cut the PT battery box to make it fit!
No new changes or improvements, (maybe I've solved them all!??!)!
The canopy WILL support 225#! I stood on it with a 10' saw pole to prune suckers up to 23' off the ground!
Muscle problems in my body and legs are 99% cured, and in my hands 90%!!!! None of my four doctors helped, so it must have been the prayers, and best wishes, from you guys!!! Thank you so much!!!!
PS: Yes! My wheels are still reversed!!
How is the chief? ;)
"Glad to hear you are doing bettery. At my age, 90% or better is the best I can hope for."
If you will do more than you think you can, you'll soon be doing more than you thought you could!!
"Could we get pictures of the changed battery box?"
As my retarded daughter often answers: "Maybe!!"
"Did you use a different battery?"
Yes. Although not as large as I would have liked, the one that I found at Wal-Mart works OK, but still required modifications to the box!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2008 Kubota M125X (A60462)
2008 Kubota M125X...
