PT-425 PROS & cons??
/ PT-425 PROS & cons?? #231
Re: PT-425 PROS & cons??
That was not an insult. It would be hard to insult someone that has a logical opinion about everything.
My 1445 came from the factory with one wheel position, the correct one, and can not be reversed.
Worrywart, That is sissy talk. I don't worry about things that might break, I simply deal with it.
I checked on the warranty, and if you want to reverse the wheels, wait till the warranty ends. If you are going to reverse, just don't tell anybody.
Scuba gear, [ dumb statement. ]
I even like Kohler engines, and Kohler does allow synthetic oil., but sometimes my stuff breaks. How about yours.
/ PT-425 PROS & cons?? #232
I was able to afford a PT because I drove an old truck for so many years! /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
/ PT-425 PROS & cons?? #233
/ PT-425 PROS & cons?? #234
I have what may be a silly question - why does PT put valves on both sides of the wheels if they are designed to be used in only one position? I have taken the wheels off of my Ford pickup and did not see valves on the other side!
/ PT-425 PROS & cons?? #235
/ PT-425 PROS & cons?? #236
One reason might be that if you use dual wheels, you would put the shallow side of the wheels together with an adapter or bolts, and be able to check the air or put air in. Other equipment might also use these same rims, and they can be used which ever way is proper.
I do not have two valve stems on my 1445. Mine are 12 rimex10.5 wide. with tires 26X12X12
/ PT-425 PROS & cons?? #237
<font color="red"> OR, it may be to facilitate wheel reversal by brave knowledgeable PT-425 owners!! </font>
/ PT-425 PROS & cons?? #240
</font><font color="blue" class="small">( in my case, a Hemi Magnum around rather than an old gas guzzling truck!! )</font>
And Hemi doesn't guzzle gas? What kind of mileage do you get with the Hemi?
In an earlier post you mentioned a new ATV, what did you get?
2020 ASV RT65 (A60462)
New Quick Attach Hay Spear (A61166)
New Quick Attach...
WATER TRAILER (A58214)
CFG Industrial H12R (A60463)
CFG Industrial...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
