PT-425 PROS & cons??
/ PT-425 PROS & cons?? #201
Re: PT-425 PROS & cons??
</font><font color="blue" class="small">( Well, I guess I'm on the fence for a while on this one. I also have to consider the smaller wheel motors of the 180.
I'm sure the 425 also has a beefier wheel motor, shaft, and bearings. Do the 422 and 180 have the same wheel motors?
)</font>
I'm not sure, but I think the 422s have the same White wheel motors that were used on the older 425s like mine and MossRoad's... the newer 425s have different, higher-torque wheel motors. I think FOURTEEN's 425 is one with the newer wheel motors, yet he still has the Kohler engine, unless I'm mistaken...
I don't know what the PT-180 uses.... /forums/images/graemlins/confused.gif
/ PT-425 PROS & cons?? #202
Well I do think there is a lot of logic in what J.J. says. Mechanically speaking, more stress does add up to shorter wheel life, along with any bearing or seals. The question is how much of a shorter life are you willing to settle for? 800 hours instead of 1000 who really knows?
Kent for your needs, and others that absolutely have to have the extra stability, I can see the trade off in reversing the wheels. Looking at some of the hills you have to transverse, I would defiantly go with reversed wheels.
For just average use around my house the wider stance would be great, but not as necessary. As far as the look, I really could care less. I didn't buy the PT for it looks. So I guess it just boils down to safety versus possible added cost later on. I suspect you are right about the 180 and 422 being the same wheel motors. I'm sure someone on here knows for sure.
/ PT-425 PROS & cons?? #203
/ PT-425 PROS & cons?? #204
</font><font color="blue" class="small">( Well I do think there is a lot of logic in what J.J. says. Mechanically speaking, more stress does add up to shorter wheel life, along with any bearing or seals. The question is how much of a shorter life are you willing to settle for? 800 hours instead of 1000 who really knows?)</font>
Yep, and your car would last much longer if you only drove freeway miles -- barring a high speed accident /forums/images/graemlins/grin.gif...
However, I have to take 20+ miles of two-lane roads to work.... /forums/images/graemlins/tongue.gif
Is it really true that JJ lives in the mountains of Florida? /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ PT-425 PROS & cons?? #205
/ PT-425 PROS & cons?? #206
Hardy har har, fellas! /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif
As long as no one gripes when it breaks I suppose it's O.K.
As for a backhoe on a 425, why, that's a highly engineered piece of equipment that falls well withing my tollerance for financial discomfort should anything go wrong. Don't forget, I have a stick welder and torches and am willing to use them! /forums/images/graemlins/wink.gif
/ PT-425 PROS & cons?? #207
/ PT-425 PROS & cons?? #208
<font color="blue"> I'd reverse mine immediately if it would still fit in the back of my pickup. </font>
As this is technically a pros and cons thread on the PT425 let me point out that you guys need to make the "pickup truck transport without a trailer" /forums/images/graemlins/cool.gif fact better known to the tractor buying community has a whole. That is one of the most outstanding "features" of the PT425 and deserves to be hollered out to all the shoppers comparing the PT to a CUT.
/ PT-425 PROS & cons?? #209
/ PT-425 PROS & cons?? #210
O.K. I'll shout it out...
I CAN FIT MY PT425 WITH A 4' BRUSH HOG ATTACHED INTO THE REAR OF A STANDARD 3/4 TON 8' PICKUP TRUCK!!! /forums/images/graemlins/grin.gif
Not just the brush hog, but a 5' finish mower, a 5' power angle snow plow, a large bucket on the FEL, just about any attachment. Fits nice, rides nice, makes for quick transport, too. The loading ramps from PT are very strong and cost about a hundred bucks. You just have to find a way to secure them to the bed (not the tailgate) of the pickup truck. Heavy ratchet straps to the frame would work fine. I chose to use steel pipe and rebar. I welded one section of pipe to the underside of the ramp and another section to the top of my steel bumper. I then slipped a piece of rebar through both pieces of pipe and the ramp is secured to the truck. We used this method to secure steel plates between railcars to load 5 ton army trucks, so I'm pretty sure it will hold a 1500 pound tractor with attachment. /forums/images/graemlins/wink.gif
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2018 Caterpillar 308E2 CR Excavator (A61166)
2018 Caterpillar...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
2021 John Deere S350 (A60462)
2021 John Deere...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
