Oil & Fuel PT 422 with Robin engine fuel filter
/ PT 422 with Robin engine fuel filter #1
MuncyBob
Platinum Member
N Central PA
PT 422
I did a quick search and found mention of the gas filter...but can anybody give me a part number(NAPA or otherwise) so I can waltz into my local store and pick up one of these....with just over 200 hours I figure it's about time to change it? I was thinking about taking the original into the store with me but not sure if the counter boys will be able to accomodate me.
/ PT 422 with Robin engine fuel filter #3
It's a very forgiving application. Any 1/4" inline fuel filter, such as a Fram G-1 should work just fine.
Gravy
The Jacks Small Engine site shows 2 that are 1/4" inlet yet the microns differs....this is no big deal??? Wouldn't the finer filter slow the fuel flow?
/ PT 422 with Robin engine fuel filter #5
The finer micron might be for a fuel injected engine. In any case, unless it's a really tiny filter, it should flow enough for this application - it will just clog sooner. Personally, I don't use a small engine filter, as you often end up paying more and getting a much smaller filter. Since there's plenty of room, I use a standard automotive filter.
Gravy
I inquired at the local NAPA storte on a cross reference to the Fram G-1 mentioned above....FYI you can get the plastic filter part# 3001 or the metal filter with new clamps part#3031.
Just an update, the NAPA plastic filter would not intsall without leaking using the original spring clamps. Also, it is suggested that you take off the small rubber fuel line joining the fuel filter with the engine and inspect it...mine is severly cracked on the outside, intereior was ok but probably just a matter of time(not much probably!) before a leak!
/ PT 422 with Robin engine fuel filter #8
Good update. Wednesday, I replaced my fuel filter and both the short and long fuel hoses as part of my 500 hour maintenance. My short hose was badly cracked also.
Dale
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
