Pt 422 mowing on a hill
   / Pt 422 mowing on a hill #1
bert145
2024 pt422
Update shut off in the middle of mowing won't start back 3.5 hrs on it
Just bought a brand new 422 trying to mow a hill about 16 degrees it will go up it fine but with the deck down the front tires spin out I have it on float any ideas that will up I thought about chains anyone else have this problem??
   / Pt 422 mowing on a hill #2
I would take it out of float and raise it slightly. That will put more weight on your front wheels.
Ken
My yard is full of slopes and dips it would cut horrible with put the float on
   / Pt 422 mowing on a hill #4
PT has a draft feature that starts with the 1430 and up, it loads the front tires. You may want to consider liquid ballast in your front tires and maybe iron weights in combination to overcome the light front end when in float.
   / Pt 422 mowing on a hill #5
Welcome! Where are located? How big a hill are we talking about? Area? Length of slopes? Any photos? Is this a lawn, or a field/pasture?
Both chains and different style tires (Do you have the lawn tread?) would improve traction at the expense of your surface. I use chains to brush cut thistle patches on 25-30 degree slopes with a 1445. Without chains, if I cut the thistles when they were particularly wet, the tractor was always sliding a bit down the hillside due to the slick thistle sap, even with draft control which is a huge help. Chains keep the tractor anchored.
Have you tried mowing later in the day? Can you figure a mowing pattern that lets you mow down the steeper slopes?
Now that you have a PT, there's also the "regrade the slope" plan, moving top soil around and filling in the subsoil.;)
All the best,
Peter
All the best,
Peter
Well now it shut off in the middle of mowing 3.5 hrs on it won't start back 😒
   / Pt 422 mowing on a hill #7
Sorry!
Does your 422 have an oil cooler fan?
All the best,
Peter
Sorry!
All the best,
Peter
Yes it has one it started back after letting it sit made it 1 lap shut off again fired up back up acted like it was Goin 2 die again so I just shut it down let it cool down and go from there
   / Pt 422 mowing on a hill #9
How full was your fuel tank? I ask because some of the 4XX series designs have had issues with vapor lock. Is that a possibility? If so, there are some simple fixes with fuel line insulation.
How old is the fuel? Could it be winter blend, rather than summer blend? Octane? Is that a Kohler engine?
All the best,
Peter
All the best,
Peter
Yes it's the Kohler I just got it yesterday I ran what gas was in it out and put 5 fresh gallons in it after it cools it fires right up and runs maybe the Hydraulic oil is getting hott but I feel like the engine should run at least.. another thing do u know why it has motor oil instead of hydraulic oil just a side thought
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54756)
DIXIE CHOPPER...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
2015 Land Rover Evoque SUV (A55758)
2015 Land Rover...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
