PT-180 digging up a Tree Stump
/ PT-180 digging up a Tree Stump
Last one.
Last one.
/ PT-180 digging up a Tree Stump #23
We all know that you were in that Git-er-done mode, and you were having fun doing it. You can also use those forks to transplant things. I drilled a hole in the ends of my forks, and installed a 2 in ball for moving trailers.
/ PT-180 digging up a Tree Stump #24
Ya, I was in a Git-er-done, just having fun mode. /forums/images/graemlins/smirk.gif
The digging was done with the small rock bucket and teeth. The pictures are with the forks after I busted the stump loose. I went back and changed the format to JPEG, so the shots are much clearer.
Yes, the forks are handy aren't they? Glad I got them. Hitch and ball on the ends? Another one of your great ideas. I can tell you've had your Pt a long time. I plan to take two pieces of cut 4x4 wood post stock, bolt them to the ends of mine, and attach a skidder with chain, for lifting and dragging trees. I think I mentioned this somewhere in another post already. /forums/images/graemlins/shocked.gif
/ PT-180 digging up a Tree Stump #27
Mission accomplished! Thanks for the great pics, Barry.
/ PT-180 digging up a Tree Stump #28
/ PT-180 digging up a Tree Stump #29
Cool! Nothing like the feeling of accomplishment. /forums/images/graemlins/smile.gif
/ PT-180 digging up a Tree Stump #30
Thanks fella’s
After all is said and done, it kind of helps justify the purchase. /forums/images/graemlins/smirk.gif
Thanks fella’s
/ PT-180 digging up a Tree Stump #33
Barry, can you use something like this? They are on Ebay
Skidding tongs.
/ PT-180 digging up a Tree Stump #34
Skidding tongs.
Thanks J.J.
Yes that is exactly what I had in mind. I plan to buy two different sizes. ( Tongs )
Thanks J.J.
I suspect it is pretty easy to tip your tractor, if a tree gets hung up on something. Guessing I'll have to tow the over size tree's low to the ground. /forums/images/graemlins/tongue.gif
Here are a few of the size I need to drag out of the woods. The Pt can lift them, but It's hard to maneuver around with out cutting them up first. I just want to drag them out in the open, then saw them up. Excuse my junk, this is where I hide it out back. /forums/images/graemlins/crazy.gif
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
INSPECTION (A65579)
INSPECTION (A65579)
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2015 TEXAS PRIDE GOOSENECK TRAILER (A65643)
2015 TEXAS PRIDE...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
