Snowblower Provonost or Luck Now Snowblower?
/ Provonost or Luck Now Snowblower? #1
keegs
Veteran Member
The County, ME
Kubota M5640SUD
I'm looking at two used snow blowers and want to try to gather some more information before I choose.
They're both in good condition, the Provonost P 680 may be in somewhat better shape than the 72" Luck Now.
The Luck Now is asking $1250. and the Provonost is asking $1800.
If you've had any experience with either of these brands, please give me your opinions.
Thanks...Keegs
/ Provonost or Luck Now Snowblower? #2
I have a Provonost. Bought it new about 20 years ago. Very well made. Shear bolts and a master link are the only things I've ever replaced. And those were due to picking up rock that was a little too big.
/ Provonost or Luck Now Snowblower? #3
They are both manufactured in Canada and replacement parts should not be an issue, personally I feel the provnost generally is engineered better and the lucnows are more of a basic farm build.
Are they both manual or hydraulic chutes are they comparable option wise?
Thanks Gents... Both have manual chutes. They seem to be priced right as far as I can tell.
/ Provonost or Luck Now Snowblower? #5
I have a Pronovost and am very pleased with it after several winters. I researched a bunch of brands before I bought it and this one came out on top for me. Good luck
/ Provonost or Luck Now Snowblower? #6
Last summer I bought a Puma like the one in Deerslayer's sig line. It was in need of paint and I think the final price was $1,500. We didn't get a lot of snow this winter, but it was fun to use on the snow that did fall here. I added a car seat motor for rotating the chute and a linear actuator for up/down. Really glad I have it. It's the only snow blower of any type - including walk behind - I've ever owned, so I can't do a comparison with anything else.
/ Provonost or Luck Now Snowblower? #7
Around here the Pronovost is by far the most wildly used.
Rugged, good design and any maintenance parts are 'off the shelf' and not special order or captive parts.
/ Provonost or Luck Now Snowblower? #8
Thanks again Gents... I looked at both yesterday. The Pronovost was the heavier of the two but the LuckNow wasn't a bad unit. They're both pretty simple machines.
Just made an offer for the Provonost.
/ Provonost or Luck Now Snowblower? #10
Provonost by far is the better blower. As stated before one is like an old piece of farm machinery and the other a fine tuned working machine. Did you look at the paddles? Someone spent some time to make them the way they should be. The gap between the paddles and rim?
/ Provonost or Luck Now Snowblower? #11
I used a lucknow for 20 years with no problems at all,,, very well made
I'm not familiar enough with these blowers to distinguish one from the other. Here's my take:
The Pronovost is heavier than the LuckNow which can have its advantages and disadvantage.
The Pronovost P680 looks to be in very good shape....somewhat better than the LuckNow. The P680 is newer... about 10 YO as the LuckNow is 30 YO.
The price for the Pronovost is $1600. ...the LuckNow is $1250.
While both will do the job, I chose to go with the Pronovost because my sense is, with it's condition, it will probably need less service/repair in the near to mid term.
/ Provonost or Luck Now Snowblower? #13
Good call....especially if you plan to keep it for a long time. The difference in purchase price will be nominal over time. Good luck and have fun with it!
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2012 Kinze 3600 Planter (A63109)
2012 Kinze 3600...
UNUSED WOLVERINE M-SB42 42" MINI ROCK BKT (A62131)
UNUSED WOLVERINE...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
UNUSED MINI HYD AUGER SET (A62130)
UNUSED MINI HYD...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
