Proposed Idea for better clamp on forks.
   / Proposed Idea for better clamp on forks. #11
I don't understand why you folks in the USA and Ca. are so wedded to bucket forks, surely it must be difficult to see the fork ends. Is it because most people are living in the dark ages and have to knock out pins to take their buckets off?
I think that some type of quick attach system is essential in this day and age. I know that some of you use the skid steer quick attachment system for changing attachments. Here in the UK, the euro bracket system has become pretty universal for the f.e.l. manufacturers, whilst the tele-handler makers tend to all use their own systems.
Here is my Kubota bucket with euro brackets welded on. Thee yellow paint is to make the hooks even easier to see. I also have included a photo of my pallet fork attachment fitted to my previous tractor, an M7040, using euro brackets. The hook on the pallet fork is for moving trailers about.
We have quick attach forks. Virtually every new tractor is offered with that option and has been for a long time.
   / Proposed Idea for better clamp on forks. #12
I was unloading sacks of concrete from a flat bed and it would carry 700lbs across the path but no way will it lift 700 lbs... just as it should be.
Isn't that a bit dicey? You're adding weight by hand, beyond what would make the system go into relief using the lift or curl functions? It can't relieve itself if the cylinder is just getting loaded externally and doesn't get the chance to move itself. Keep loading it further and further that way and at some point it has to pop a hose or worse, especially driving over some trivial bump.
Or maybe I misunderstand what you're doing?
700 isn't much, maybe that's why?
   / Proposed Idea for better clamp on forks. #13
Nope. You need the fork itself to be the lowest thing to the ground. How do you slide it under a partially broken pallet, etc? Your design would be bulldozing dirt or scraping pavement constantly, at that "cross brace" by the bucket front lip.
Kudos for thinking hard enough to attempt some problem solving here though.
Anyway the real answer is just to have SSQA forks on your SSQA loader, screw clamp ons of any variety. :p
   / Proposed Idea for better clamp on forks. #14
So im not hating on it. It's a good idea, assuming your bucket top rail will already accept and retain the things. But the problem is as Kenny said, it can't be made universal enough to be a 'business idea'. Certainly something you can do for yourself and end up with with something better than clamp-on forks. But i see the main advantage of it not necessarily being the strength, but moreso that it could be built in such a way that you could pick them up and drop them without getting off the tractor.
In the end the easiest non-ssqa design for doing so would be the 'over the bucket' forks typically used by industrial TLBs, but those are not so limited by lift capacity or counterweighting or even operator's visibility as a small tractor would be.
   / Proposed Idea for better clamp on forks. #15
Someone on TBN made some wood forks following the same principle. They would work for brush lifting modest weight. The design is certainly better than clamp on.
   / Proposed Idea for better clamp on forks. #16
Clamp on bucket forks are a big no for me. First problem is lift capacity is limited due to how far out the load is, secondly you can't see that you are doing with them. Just no! LOL
   / Proposed Idea for better clamp on forks. #17
Sorry that you think we live in the dark ages, mate. I think most of us Yankees realize that bucket forks have disadvantages and limitations. But some us of are doing things within the bucket fork's limitations, and we believe in using our ingenuity to come up with inexpensive solutions without having to run out and buy another implement. I think I have somewhere close to $0 tied up in my bucket forks that I fabricated from scrap metal, and am quite happy with something that is considerably less than perfect.
   / Proposed Idea for better clamp on forks. #18
😂 Dark ages huh.
Call me an ******* but unless you built your quick attach, don’t take too much credit for it. If you can’t build it you buy what the market offers you and if the market didn’t offer it to you you wouldn’t have it. Good thing somebody else built it so you can have it. Very convenient. :)
Tractors in general were primarily created for agriculture. At some point in history somebody probably asked a farmer “why do you bother growing all that when you can just buy it at the supermarket, way easier!” Hmm let’s think about this. 😂
   / Proposed Idea for better clamp on forks. #19
Quick attach forks are way better than clamp on forks'
Clamp on forks are way cheaper than quick attach forks.
People buy clamp on forks if:
  • Don't need them a lot or can't justify the cost
  • Don't have to move heavy loads
  • Want them for moving brush (they work great for that)
  • Don't have a SSQA mount on their loader
Are clamp on forks the best option for everybody? Nope. Do they make sense for some? Yep.
   / Proposed Idea for better clamp on forks. #20
The more I ponder it, the more I think clamp on forks should get ruled out for a reason I haven't seen yet here:
With clamp on forks, if you accidentally catch something sturdy enough on the end that you didn't mean to and you can't see it, you're at risk of bending your bucket even if everything else you do is reasonable.
Whereas, using just an OEM bucket, or using just pallet forks, I bet you could move the levers any way you want to, and you won't damage the equipment, you just might drive it into relief.
I bet clamp on forks can easily damage your equipment without anything going into relief. There's no safety check.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
Parker Gravity Wagon (A50775)
Parker Gravity...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
New Three Point Hitch Trailer Mover (A54865)
New Three Point...
Steiner VA242 Post Hole Digger (WORKS GOOD) (A50775)
Steiner VA242 Post...
