Property Question
   / Property Question #1
paulsharvey
Elite Member
Hawthorne, Fl
Kioti CK2610 HST
So, we continue looking for properties, which I've posted several times over the last 3 years about. Wife found one that appears to tick the boxes, and more. It's got a remodeled 3/3.5, 2400 sq ft home, and 10 acres of land, with a small pond. It clearly has 10 acres, per property appraiser, and ad, but something seemed off. I did a drive by, and really matched what I thought I saw on aerials; seems a Lot smaller than 10 acres, more like 3-5? Did some more detailed looking, and it has 4.1 acres where the home is, connected to another 5.5 acres in a low land praiere, by a 8-10 foot deeded piece of property that snakes around at odd angles, to get to the 5.5. So, what I'm wondering; how much would you even begin to value 5.5 acres that Does have a deeded connection, but difficult to access, that may be seasonal under water, and definitely unbuildable. Sure, it's better than not having that 5.5, but how much above $0, would you add to the 4.1 and home?
   / Property Question #2
First thing I'd do if I was at all interested in it as I'd have a certified survey done and the property lines marked. Far as the not contiguous parcel, that would be whatever unimproved land is going for per acre where you are looking and I have no idea as it's not local for me.
   / Property Question
Technically, it is contiguous, as it's an 8-10 ft wide piece of the same parcel that connects it to the lower piece, all as a single parcel. That 8-10 ft (scaling, says 8 ft wide, but probably actually a 10 feet strip) is all part of the same parcel. That would be the only access to this lowland piece too, no other way in, without trespassing. This lake bottom/praiere is Not Sovereign Submerged Land or Tiff Property, so you technically own it 100%, but in times it's underwater, anyone can go across freely.
That 10 foot access, which isn't cleared, would be difficult to manuveure with even a SxS or small tractor, with the 90 degree turns.
   / Property Question
I'm wondering what the reasoning for these parcel shapes is. I could 100% understand a Pie of the parcel extending into old lake bed/praiere, but its just really weird to see a piece like that, with many other parcels also having 'trails' leading to their own polygon of lake bottom.
   / Property Question #5
My last offer was contingent on survey...
Learned a lot from survey and for me well spent even not buying because of issues discovered.
10' here would be a problem even for a driveway... not even addressing slopes and obstacles.
Does it make sense just the home and the lower part has no value?
   / Property Question
Maybe the better question, would be, what would you value 5.5 acres of difficult to access wetlands, that is dry enough most of the year to drive on, but can not be built on. If it was swamp instead of praiere, it would be much better as a hunting area, but this looks like a mix of praire and dried up lake bed.
   / Property Question #7
Around here, that is referred to as an 'easement' I think your issue would be if anyone else has access to it and if anyone else uses it. I'm in kind of the same boat myself as I own property that isn't connected to the main farm parcel and what I (we) did was we spelled it out plainly on the deed that the 'easement' is for our use only and cannot be used by anyone else without our express, written permission. Now, I do rent that parcel out for row cropping and I plainly state in writing (notarized) that the easement is for ingress and egress only and no parking of any equipment will be allowed on it. In our case, there is a culvert in the mix and I have to maintain that culvert at my expense. Our parcel is a lot bigger then yours is, ours is 53 acres and includes some woods as well.
   / Property Question #8
That really looks like a mess to me. 1/2 of your property is somewhat remote, likely unusable, and there appears to be four other properties accessing lots via paths adjacent to each other on the winding 8' section.
A lot of conflict potential with the wrong neighbors.
   / Property Question #9
This is pretty much a mess.
Your blue marking obscured whether part of the 8 foot access is also part of a developed street, but it appears that it is. If so that is a negative. Also, there appears to be another road or driveway that crosses the 8 foot strip. If so, another negative.
In locales I am familiar with, the parcels would be more intact, with an easement for access between. I am not familiar with a "snake road" that is owned and deeded land, so maybe that is normal in your area or maybe something odd.
Your diagram is showing in yards, so I am guessing you have some sort of a GPS system which, notoriously, usually supplies something of a "cartoon" picture of property. I would not rely upon that very far.
I would head to the County Recorder or Assessor office and pull the parcel info, deeds, and more for review.
Unbuildable land with difficult access-- if it were me I would add zero value. Maybe negative value if it serves no added purpose but if you need to insure it or could potentially be liable for risk of something that might occur on that particular land.
I would focus on the residence and residence parcel and pretty much ignore the rest-- not sure why you would even want the "extra" land-- doesn't sound like it offers benefit?
   / Property Question
Well, the price is pretty much in line, or better, than comparable. It's kinda the difference between, hey, that's an OK piece that works for us, but kinda small (4.1 acres), and hot damn, that awesome, (10 acres), and now, I'm not sure what I would even do with that piece. I imagine it could be used for some stuff, maybe gardening, food plots, live stock, shooting range, ect.
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2007 Polaris Ranger (A50514)
2007 Polaris...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
