Proper trailering
/ Proper trailering #11
I also check my load whenever I stop for fuel or whatever.
I have heard stories of people flipping binders or unlatching trailers and such at rest stops, restraunts and such.
How stupid!! Who would unlatch a trailer or flip a binder on someone else's trailer, and why? That's just pure insane, ignorant, stupidity.
/ Proper trailering #12
People do stupid stuff. I know a guy who flys a Lear Jet. He had to stop in Detroit on his way back from Canada to clear customs. In and out of the airplane in 10 minutes and when he went to take back off towards Indiana both engines blew up as he advanced the power for takeoff. They tore them down and found D Cell Batteries in both. Someone tossed the in the engines in the 10 minutes he was in the customs office. Did 2 million in damage and could have killed him, his co pilot, and 6 passengers.
Chris
/ Proper trailering #13
Chris
Stupid! Any further comment from me would be inappropriate for this "famliy friendly" forum and I'd likely be banned. I'll just foment in silence and let the thread continue.
/ Proper trailering #14
Chris
i had an old 50's jd420 crawler on my trailer for a couple of nights in a parking lot at a public boat landing. when i next used it, it was running on one cylinder. spark plug removal showed one plug gap totally closed. inside a cylinder were two small steel roll pins. they must have been dropped down the exhaust and filtered their way into the cylinder. they rattled around in there for some time and been caught between the piston and plug, closing the gap. lots of light damage, but it still works years later.
totally unrelated to trailering safety, but more evidence that some people shouldn't be allowed to breed.
/ Proper trailering #15
So, what is the rule of thumb for tying down a load? I've always considered the load safe if each strap is rated to hold the full weight of the load. I.e. every strap on a 2,000 pound load needs to be rated to hold the full 2,000 pounds.
Of course the tie down points have to hold up too.
I remember from back in my CDL days to check the load every 150 miles. I typically check within the first few miles of a trip and retighten as necessary after the load has had a chance to shift.
Here is the "official" quick answer sheet from the feds.
Cargo Securement Rules - Federal Motor Carrier Safety Administration
/ Proper trailering #16
glad that's the quick answer... i'd hate to see the long one. :D
one point of note... the second line states: "operating in interstate commerce". i haven't read this entire article, but this is often a loophole for the weekend warrior. i had discussions with the state police about my trailer when i built it, and found that i didn't need to comply with certain regulations because it was for private use only. i stand by my other comments about trailering being a gray area for small trailers (non-cross country).
/ Proper trailering #17
I have also had a 8,000# boat come forward on a 2,000# trailer.
The boat was secured with a 2" 10,000# strap at the bow, 2 more at the transom, and a safety chain at the bow but all did no good when metal breaks.
Chris
In my experience, the two transom straps would be the final hope for stopping forward motion in 99.9% of the cases. Normally the boat transom overhangs the rear bunks / rollers etc and the straps (usually connected to the transom eye bolts) have to be hooked at some more forward point on the trailer. The straps may hold the boat from going backwards on acceleration or down from bouncing, but will probably allow several feet of forward motion if the front restraints break - as indicated in your example.
/ Proper trailering #18
You are 100% correct. The straps were slack and like I said the only thing that keep 8,000# of boat out of the bed of my Ford Truck was the fact that the outdrive hit the rear most trailer cross member.
Chris
/ Proper trailering #19
I guess if one was so inclined, you could fab a way to put a padlock on your binder(s). Similar to using bailing wire.
I usually put a padlock on the coupler of bumper pull trailers, ALWAYS put one on the 5th wheel.
/ Proper trailering #20
I had someone pull the pin on tilt bed trailer in a store parking lot. When I got on the highway to speed the trailer tilted scaring the heck out of me. I know the pin was in the trailer before I entered the store because two men helped me unload a heavy load that would have tilted the trailer with such weight on the rear of the trailer. Some people are mean some are stupid some are both.
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
2014 FORD F-150 (A60736)
2014 FORD F-150...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
1964 Mercedes-Benz 190D Car Sedan (A59231)
1964 Mercedes-Benz...
