3-Point Hitch Proper technique for tilling
   / Proper technique for tilling #1
generalbegg
Ulen, MN
Kioti CS2410
Hey all, I've got a complete newbie question about tilling. I got my new tiller hooked up to my cs2410 today for the first time. When tilling I used the 3 point hight adjustment to set the tiller down. Do I leave the hight adjustment knob down while tilling, or put it back in neutral? As I was tilling with it in the neutral position, I noticed that when I would go over bumps the tiller would be pushed up and then stay at that height so if I didn't catch it, I wouldn't be tilling as deep. I'm just not sure if is ok to leave it in the down position.
   / Proper technique for tilling #2
I use the depth adjustment on the tiller for the depth control and put the 3pt all the down.
   / Proper technique for tilling #3
Put the 3 pt down as far as it will go and let it float. Use the skid shoes on the tiller to adjust height if you don't want it at full depth.
   / Proper technique for tilling #4
Depends on how your tiller operates, especially in virgin ground. I sometimes use the 3pt to hold the tiller up on first pass to reduce bounce, and let it just slice into the sod. Then progressive lower it as I make a second pass. If the ground is already tilled, I set the 3pt all the way down and go, using the tiller skids to adjust depth.
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
Takeuchi TB260 (A50120)
Takeuchi TB260...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
Deere 317G (A50120)
Deere 317G (A50120)
Kubota SVL97-2 (A50120)
Kubota SVL97-2...
