proper hydraulic level
   / proper hydraulic level #1
ozarkbru
Ozarks
Kubota B7800
I've got a 05, B7800 HSD with a 100 or so hours on it . Started noticing a problem with hydraulic priming after a filter change and a top off of UDT last winter, I figured it was the 25 degree temps.
My question is when checking the fluid, engine off, nothing is on the dip stick on first check and then reads at the top level on recheck.
Should this be checked with the engine running like most car transmissions?
   / proper hydraulic level #2
Common question-the second reading is correct.Engine off and FEL lowered is the correct procedure.Something about vacuum sealing allowing the fluid to not show on the dipstick.Many posts through the years about this.
thanks for the good info,,,,,,
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
