proper hydraulic level
   / proper hydraulic level #1
ozarkbru
Ozarks
Kubota B7800
I've got a 05, B7800 HSD with a 100 or so hours on it . Started noticing a problem with hydraulic priming after a filter change and a top off of UDT last winter, I figured it was the 25 degree temps.
My question is when checking the fluid, engine off, nothing is on the dip stick on first check and then reads at the top level on recheck.
Should this be checked with the engine running like most car transmissions?
   / proper hydraulic level #2
Common question-the second reading is correct.Engine off and FEL lowered is the correct procedure.Something about vacuum sealing allowing the fluid to not show on the dipstick.Many posts through the years about this.
thanks for the good info,,,,,,
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2020 JOHN DEERE 8R 250 LOT IDENTIFIER 172 (A53084)
2020 JOHN DEERE 8R...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
2006 HAMM 3205 SMOOTH DRUM ROLLER (A51246)
2006 HAMM 3205...
