proper hydraulic level
   / proper hydraulic level #1
ozarkbru
Ozarks
Kubota B7800
I've got a 05, B7800 HSD with a 100 or so hours on it . Started noticing a problem with hydraulic priming after a filter change and a top off of UDT last winter, I figured it was the 25 degree temps.
My question is when checking the fluid, engine off, nothing is on the dip stick on first check and then reads at the top level on recheck.
Should this be checked with the engine running like most car transmissions?
   / proper hydraulic level #2
Common question-the second reading is correct.Engine off and FEL lowered is the correct procedure.Something about vacuum sealing allowing the fluid to not show on the dipstick.Many posts through the years about this.
thanks for the good info,,,,,,
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2020 John Deere S790 Combine (A53342)
2020 John Deere...
