propane torch set up
/ propane torch set up #1
jack707
up North wisconsin
farm trac 555
Can someone tell how this is as far as cutting?. I needed a torch set up so I called Missippi welder supply and for 200. I can own my own tank of oxygen it will be 3 foot tall then I could hook up a a small tank of propane to cut and gas weld on some of my mods. I do to my traps.
/ propane torch set up #2
What would you like to know? I switched to propane a few years ago.
/ propane torch set up #3
You will NOT be able to weld with propane.
You mean with a propane flame I wont be able to weld? why is that?
/ propane torch set up #6
Well, I'm no welder and don't play one on TV but I've been brazing or welding or whatever you want to call it using propane and oxy for over 30 years in my home shop. Don't use it often as I now have mig and tig and plasma but have had no problem repairing an old muffler or patching something up. Used existing welding tips. As far as cutting goes, no problem. Had to use a tip designed for propane but that's the only change I had to do to switch to propane. More experienced users may have other and better suggestions. Probably numerous discussions about this topic on Google.
Al
/ propane torch set up #7
I think propane makes some really nice cuts:cool:. Just takes longer to preheat:( before starting the cut is all.
/ propane torch set up #8
Propane doesn't produce CO2 as a shielding gas the way acetylene does. Oxygen therefore contaminates welds and that makes for brittle weak welds. Propane cuts great. Brazes well too but doesn't weld.
Thanks for schooling me! time to rethink this again.
/ propane torch set up #10
If I remember correctly while back there was an acetylene shortage and if you are doing a lot of heating with a rose bud, acetylene can get expensive. Propane has its advantages, I have not converted over yet. Next shortage!
/ propane torch set up #11
In some countrys, they call all forms of joining metals 'welding'. As in solder welding, braze welding, fusion welding. In other countrys, welding means fusion welding. Brazing is brazing. Soldering is soldering.
I suspect what you have been doing is brazing, or 'braze welding' with some kind of non ferrous filler metal like brass or bronze.
Oxy-propane is a good process for that as well as well as oxygen cutting and general heating.
If you want to melt steel to join two pieces together with a flame, you need to use oxy-acetylene.
/ propane torch set up #12
Oxy-acetylene burns a lot hotter than Oxy-propane and uses less oxygen. Part of the money you save by using propane you spend on more oxygen.
/ propane torch set up #13
I've always heard this. I never kept track of my oxygen usage when cutting with acetylene:eek:. About a year or so ago I had some cutting to do with propane, and I tracked the oxygen usage.
A 250-CF bottle of oxygen, gauge set at 40-PSI. I made 46 cuts 21-inches long in 1/2-inch thick steel. Using a #3 tip. That is 80 1/2 feet of cutting with a 250-CF bottle of oxygen. Now that is shutting the torch off, and re-starting it after each cut.
A 250-CF bottle of oxygen cost me just under $30.00.
/ propane torch set up #14
I've always heard this. I never kept track of my oxygen usage when cutting with acetylene:eek:. About a year or so ago I had some cutting to do with propane, and I tracked the oxygen usage. A 250-CF bottle of oxygen, gauge set at 40-PSI. I made 46 cuts 21-inches long in 1/2-inch thick steel. Using a #3 tip. That is 80 1/2 feet of cutting with a 250-CF bottle of oxygen. Now that is shutting the torch off, and re-starting it after each cut. A 250-CF bottle of oxygen cost me just under $30.00.
You can't leave us in suspense... What project required 46 identical cuts in 1/2" steel???
/ propane torch set up #15
I could be wrong but thinking back to old training, I was told that Propane uses more oxygen than acetylene only during preheat. Cutting is nearly the same. Something to do with the fluted tips requiring a little more oxygen that the standard acetylene tip to bring the flame to the desired setting. The cutting oxygen hole in the tip is sized nearly identical to the acetylene tip for the same cut thickness. Some manufactures make 1 piece propane or alternate fuel tips with the thought that they use a little less oxygen. I'm not sure if consumption on the 1 piece tips is less but I use them. I like the way the preheat and cut. In the end, The extra oxygen usage is negligible because of the fuel gas saving from acetylene to alt fuels. Just be careful lighting Alt. Fuels out in the wind. I'm a Plasma guy but I grab the Gas Axe quite often when hacking steel. Fun stuff.
/ propane torch set up #16
Cutting a 37 1/2 degree bevels on 6-inch schedule 80 pipe.
Those that are willing to come to my shop, I help them with their welding. ;)
/ propane torch set up #18
Very nice cuts you made there !!!
Did you use a device/guide to make that bevelled edge on that pipe ?
/ propane torch set up #19
I converted my machine torch from my tractor torch, to work with my weld positioner.
/ propane torch set up #20
Very nice, thanks for the extra info & pictures.
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
POLARIS RANGER XP900EFI RTV (A59823)
POLARIS RANGER...
STAINLESS STEEL FILTERS (PALLET) (A60736)
STAINLESS STEEL...
MAGNUM LIGHT TOWER (A60736)
MAGNUM LIGHT TOWER...
