propane torch set up
/ propane torch set up #1
jack707
up North wisconsin
farm trac 555
Can someone tell how this is as far as cutting?. I needed a torch set up so I called Missippi welder supply and for 200. I can own my own tank of oxygen it will be 3 foot tall then I could hook up a a small tank of propane to cut and gas weld on some of my mods. I do to my traps.
/ propane torch set up #2
What would you like to know? I switched to propane a few years ago.
/ propane torch set up #3
You will NOT be able to weld with propane.
You mean with a propane flame I wont be able to weld? why is that?
/ propane torch set up #6
Well, I'm no welder and don't play one on TV but I've been brazing or welding or whatever you want to call it using propane and oxy for over 30 years in my home shop. Don't use it often as I now have mig and tig and plasma but have had no problem repairing an old muffler or patching something up. Used existing welding tips. As far as cutting goes, no problem. Had to use a tip designed for propane but that's the only change I had to do to switch to propane. More experienced users may have other and better suggestions. Probably numerous discussions about this topic on Google.
Al
/ propane torch set up #7
I think propane makes some really nice cuts:cool:. Just takes longer to preheat:( before starting the cut is all.
/ propane torch set up #8
Propane doesn't produce CO2 as a shielding gas the way acetylene does. Oxygen therefore contaminates welds and that makes for brittle weak welds. Propane cuts great. Brazes well too but doesn't weld.
Thanks for schooling me! time to rethink this again.
/ propane torch set up #10
If I remember correctly while back there was an acetylene shortage and if you are doing a lot of heating with a rose bud, acetylene can get expensive. Propane has its advantages, I have not converted over yet. Next shortage!
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2011 International Prostar Premium (A60462)
2011 International...
2018 Dodge 5500 Bucket Truck 4WD (A61307)
2018 Dodge 5500...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
