Propane Regulator Froze Up
   / Propane Regulator Froze Up #11
Up here in the great white north, the temp will occasionally get down to -20F. We've had our propane fueled hi-efficiency forced-air furnace since Jan 1991.
Never had a freeze up... high pressure regulator on the tank about 80 ft from house, low pressure regulator at the house, north side... back then the installers put a fitting on the vent port of the regulator and ran an underground line to a fence post about 20 ft from the house, because the regulator/entrance point was a few feet from a basement window. I suppose in our situation, the regulator should be even more protected from moisture/freeze-up.
must be an issue with your regulator...
   / Propane Regulator Froze Up #12
I had natural gas at my house the meter and reg was covered in ice no gas I called the gas company . The guy shut the gas off and used a propane torch to melt the ice off the regulator
   / Propane Regulator Froze Up #13
Similar situation here but propane only used for cook stove. When OAT gets down to single digits and / or there is ice and snow buildup on the regulator and tanks it freezes up and I have to go out with a heat gun to warm it up. Been doing this several times a year in winter for many years.
   / Propane Regulator Froze Up #14
Never heard of an LP regulator freezing up here and it can get pretty cold. A friend does commercial heating and encountered a nat gas meter freeze-up once at a nursing home that required him to break the seals to get the heat back on but that was a component failure...guess they are all simple diaphragm type things and they can fail.
   / Propane Regulator Froze Up #15
Here's the story on propane regulators freezing(your supplier should know this and take care of it for you). This apply's to any system from 5 gallon grill bottle to several hundred gallon storage tanks. If a large amount of gas is flowing,a properly working regulator will be cooler than surrounding air,even in warm weather unless sun is keeping it warm. It is due to pressure drop inside regulator. In freezing temperature with moist air,ice can form on regulator without effecting function. Even when weather stay's cold and moist for days causing a thick layer of ice,the regulator will still function,,,,UNLESS,,,,,regulator has moisture INSIDE. A single drop of water inside regulator will shut it down. Moisture get's into tank and lines during assembly or is introduced when tank is being filled. If one has been using same system for a few years in similar weather without a problem and regulator stop's flowing,I would thaw it out and not worry unless it reoccurred shortly. In that case,I would choose a day with low humidity to pour denatured alcohol in regulator and tank side of line at regulator. Use fresh unopened alcohol and work fast to open and close line. If you remove regulator,plug both lines while regulator is off. If it happen's again shortly,chances are the tank has water in it. The supplier can transfer your fuel into another tank and pour alcohol into your tank. Few will do it but it is much better to pull a vacuum on tank to remove all traces of moisture (exactly same procedure air conditioning techs do every day). In actuality the principle of pressure drop equating to cooling effect is exactly what make's your refrigerator and air conditioners work. If you buy an empty used tank,beit a grill bottle or large storage tank,you should take remedial measures for water. Water lay's at bottom of tank so if there's a great amount, most can be poured out by inverting tank. A word of caution. The water contain's odorant and if you get it on you or your clothes it's next to impossible to wash off so be very carful. That's why few suppliers are willing to evacuate tanks. Ditto for your buddy who own's a refrigeration vacuum pump. His pump will stink after evacuating a propane tank. Now you know why some regulators freeze and others don't.
   / Propane Regulator Froze Up #16
I suppose that with this year's LP shortage we might have a situation where inferior gas got into the system. I have noticed that on the gas grill from time to time where it just didn't seem to burn right. As for the "stink", my shop has run out of gas twice (even though it's on "keep-fill" and "pre-paid"). Both times I knew it immediately when I opened the door.
   / Propane Regulator Froze Up #17
"my shop has run out of gas twice (even though it's on "keep-fill" and "pre-paid")"
Let me guess,there's no competition in your area. In Texas where running out is far less critical,compitition is furious and suppliers give you guarantees you will never be without if you sign up for keep filled. That is rapidly changing as Amerigas buy's out small companies.
   / Propane Regulator Froze Up #18
We live in "propane country" so competition is not the problem. We lease the tanks from the local Co-op meaning we are "married" to them. They are consolidating with other local Co-ops and seem to be having great difficulties in managing the "synergies". That was outage #1 in the shop a few years ago where new drivers merely forgot to fill when they filled the house tank not far away. The latest outage was due to the recent shortage where they were trying to ration supplies...wet grain led to a lot of drying and then we ran into what is probably one of the coldest winters on record.
   / Propane Regulator Froze Up #19
Regulators are sized for the amount of flow/BTUs needed. The bigger they are the more money they are. As you are seeing several folks in very cold climates don’t have issues.
If it’s undersized it can create a condition that would cause some internal freezing issues as the propane goes from highish to low pressure (also correct above regarding two regulators).
This is a long shot that hasn’t been mentioned- not the first thing to look at.
Bottom line- their are millions of propane regulators in this world that don’t need special care or maintenance depending on temperature- they just work till they don’t.....unless it was the wrong one to begin with (too small, wrong size etc)
   / Propane Regulator Froze Up #20
I had this same problem last year on 2 different propane installations. They were both 125000 BTU hot dawg heaters. When it got down below 0 one or the other would freeze the regulator and the heater would go out. They changed regulators tried different things for a couple of weeks. Then they finally put a heavy dose of what ever kind of alcohol they use on propane for moisture and the problem went away on both units. This year no problems and it has been colder this year than last year. Both of my heating units, tanks and all equipment was new when installed. After problem went away with alcohol they figured there was some moisture in the new tanks. Hope this helps your situation.
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
KUBOTA M7-132 (A53084)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
