Here's the story on propane regulators freezing(your supplier should know this and take care of it for you). This apply's to any system from 5 gallon grill bottle to several hundred gallon storage tanks. If a large amount of gas is flowing,a properly working regulator will be cooler than surrounding air,even in warm weather unless sun is keeping it warm. It is due to pressure drop inside regulator. In freezing temperature with moist air,ice can form on regulator without effecting function. Even when weather stay's cold and moist for days causing a thick layer of ice,the regulator will still function,,,,UNLESS,,,,,regulator has moisture INSIDE. A single drop of water inside regulator will shut it down. Moisture get's into tank and lines during assembly or is introduced when tank is being filled. If one has been using same system for a few years in similar weather without a problem and regulator stop's flowing,I would thaw it out and not worry unless it reoccurred shortly. In that case,I would choose a day with low humidity to pour denatured alcohol in regulator and tank side of line at regulator. Use fresh unopened alcohol and work fast to open and close line. If you remove regulator,plug both lines while regulator is off. If it happen's again shortly,chances are the tank has water in it. The supplier can transfer your fuel into another tank and pour alcohol into your tank. Few will do it but it is much better to pull a vacuum on tank to remove all traces of moisture (exactly same procedure air conditioning techs do every day). In actuality the principle of pressure drop equating to cooling effect is exactly what make's your refrigerator and air conditioners work. If you buy an empty used tank,beit a grill bottle or large storage tank,you should take remedial measures for water. Water lay's at bottom of tank so if there's a great amount, most can be poured out by inverting tank. A word of caution. The water contain's odorant and if you get it on you or your clothes it's next to impossible to wash off so be very carful. That's why few suppliers are willing to evacuate tanks. Ditto for your buddy who own's a refrigeration vacuum pump. His pump will stink after evacuating a propane tank. Now you know why some regulators freeze and others don't.
