Propane Prices
/ Propane Prices #291
can anyone ballpark the cost of a 500 and 1000 gallon underground tank if one wanted to purchase one?
Wondering if my usage of about a thousand bucks of propane a year would provide any justification for buying my own tank. I know I could likely save 20 or 30 cents per gallon, but just say I could save $200 to $300 per year.
Wondering how many years to get that back.
And...I bet it would cost four figures to get someone to dig up my back yard, avoid the septic systems and put in a new tank. I neither have a backhoe nor know how to use one, so not going to rent a backhoe on this. And frankly I would sure want someone who knew what they were doing.
When I learned there was a 80 cents difference in my local company's "preferred retail" pricing track than their
employee price, I knew there was tons of profit here. But you know...they take care of the equipment and make a profit of what, three hundred maybe four hundred bucks a year off me. Add another zero and I'd be digging myself, but I don't want to spend 5 grand to save three hundred dollars a year. Nor do I like getting ripped off...
the other alternative is to just tell them to take their 500 gallon above ground tank back and find another one of those, which I assume is both easier and cheaper than an underground tank. Anyone who has gone through this cost calculation process, would be interested to hear if the numbers worked for you.
/ Propane Prices #292
I just ran into the "tank rental monopoly" last fall here in rural Maine. A local company sold me a three-year-old 500 gal. tank for $1 K installed (above ground). Expensive, but now I have the option of buying from the lowest price supplier. Bulk pricing saved around 60 cents per gallon, so it should pay for itself in about five years.
/ Propane Prices #293
Thanks. Five years is fine. That would work for me. Maybe ten at the most. This is right in the middle of my nicely landscaped back yard. I was hoping to bury it
since they seem to allow that now versus fuel oil tanks which for residences in many areas have to be dug out of the ground by code. Been there done that.
So I'm probably doubling the cost and looking at ten years.
/ Propane Prices #294
Daugen,
Another option is to first price the cost of a new 500 above ground, if that's what you have. Then call your current propane company and ask them if they'll sell you their tank. The price should be a good amount less for the used tank.
As to the 1000 in-ground, the tank will cost near $3000, and installation and other costs may bring the price to $5K. I've heard of less, but that's what it cost me. Except for esthetics, space consideration, earthquake safety etc, (which played a part in my decision), it is more cost effective to get an above ground and paint flowers on it (or something) :c). Payoff will likely be quicker than you think - I've been averaging $1 a gallon less, but the captive customer companies here keep their prices as high as possible.
/ Propane Prices #295
Local supplier told us that if we owned 1000gal tank, it would have to be re-certified every 5 years or something, but if we rented, they would take care of tank. We rented (mostly because we could not afford to buy our own tank) and they have done nothing to the tank for 24 years. We get a decent price and only need to fill annually. We use about 400gal.
/ Propane Prices #296
Local supplier bs. It's to their advantage to rent you the tank AND keep you captive because you have their tank.
/ Propane Prices #297
As Pixguy said, total garbage! Keep in mind that those companies do not want you to own your own tank. As long as you rent from them (or even if some let you use their tank for free, which is also common), they *HAVE* you as their customer - basically a monopoly. They know most customers will not bother to switch if they are paying a bit more than they need to, or even more than a bit more. Most customers won't shop when that's not convenient to do and most won't then use that info to complain to their "sole provider".
Did you know that even with a rental tank, you can demand that they call you with pricing *before* the deliver (at least in most states)? This is recommended as it gives you a chance to squawk loudly if you think you are being fleeced. You can also tell them to come get their tank - by law, in most states they are required to do that for free, and to measure and refund you for the propane remaining in the tank, all on their dime. They do not want to do this, as it costs them and they lose a customer. You can then get another company to install their tank, also for free - check ahead of time if they have fees, most will waive them if you insist. When you talk to a propane company about buying a tank they may dump the "maintenance" threat on you, telling you that when you rent, they take care of all that. Yes, that's true, but maintenance is rarely required. How often has your tank or regulator required service? When you own the tank, the company you are buying propane from will gleefully provide any repair required. Some things, like the gauge face, are easy to replace by the customer on most tanks, and failure there isn't common either.
Still, by far the best option is to own your own tank, IMO.
/ Propane Prices #299
I have read over some of the post here and a lot of good information shared. The only thing I would add is when you are dealing with your supplier be very aggressive as to what you will pay versus what they want you to pay and most time if you are in ball park they will agree. The propane industry has suffered 2 warm and mild winters and they need to move propane. In some cases they will wave the rental fee and you pay nothing for that, you can also lock in a price for as long as 2 years in some cases.
/ Propane Prices #300
Grain farming areas get a break because a lot of the propane is used for grain drying and after the fiasco a few years ago more storage has been added. I rent a 500 gal and 250 gal tank from the Co-op that supplies the farmers and as long as one fill goes through it every year there is no rent. We get the choice every year (July) whether to #1 "go naked" #2 "pre-buy" at a set price (determined before I know the moisture content of corn and beans and well before I know the winter temperatures) or #3 Pay $70 to have the price "capped" at the level they determine in July. This year I opted for #2 at a $1.14/gal. (the "cap" price was $1.49 at the time). I exceeded my "pre-buy" allowance by about a 75 gals but the current market price was $1.16 for the excess about 2 weeks ago.
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
2018 New Holland C227 Compact Track Loader (A61307)
2018 New Holland...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2015 Audi A4 Sedan (A59231)
2015 Audi A4 Sedan...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
