Propane installation - Above or Under Ground?
   / Propane installation - Above or Under Ground? #22
Holy cow. I installed a buried 1000 gal tank 4 years ago. Tank cost $2,000 plus propane. I paid for hole and burial material.
here, they fill underground to 90%
   / Propane installation - Above or Under Ground? #23
Underground would be safer in a fire. The above ground tanks turn into flame throwers and sometimes explode.
In my county above ground tanks have to be bolted down to a slab, due to earthquakes. And if they are placed where it's possible to drive into it they need bollards.
The cost for the above ground tank may include features like that.
   / Propane installation - Above or Under Ground? #24
Looking into adding a generator. My propane provider just quoted me $3800 to purchase a second 250 gallon tank. They won't rent a tank for just a generator and the house tank is about 400-500 ft away (further than I want to trench).
   / Propane installation - Above or Under Ground? #25
From the thread I created about propane generators, 250 gallon propane tank is right on the brink of not being large enough to vaporize propane to keep a generator running. Make sure you are certain it will work.
   / Propane installation - Above or Under Ground? #26
Guess I'll need to get smart on vaporization rates. I was just sizing the tank to guesstimated usage.
   / Propane installation - Above or Under Ground? #27
I have had them all. I had owned a 1000 gallon buried. I rented a 500 gallon buried. I owned a 500 gallon above ground. Now down to a 300 gallon above ground.
Biggest advantage for me buried is the explosion a tank causes in a fire.
But for what they cost I would rent now.
The explosion hazard for propane tanks from wildfire is not the concern that lots of people think it is. I did wildland fire management periodically for almost 25 years. I’ve seen lots of wildfires burn under and around propane tanks without tank blevy issues. The key is to not have heavy fuels such as trees and brush adjacent to the tank. If the tank is in a cleared area and low intensity grass fires burn under it, I’ve never seen that type of fire cause a tank explosion (blevy).
   / Propane installation - Above or Under Ground? #28
That is a total rip off. Just rent a 500 gallon tank like I do. The only cost $60 Canadian per year.
   / Propane installation - Above or Under Ground? #29
Yup, I seen a lot of fires and a lot of tank bleve. It is something to see. Smaller properties don’t have a lot of choices for tank placement.
   / Propane installation - Above or Under Ground? #30
Just got a quote to install a new 500 gallon tank and put 400 gallons in it. $6,000 for above ground and $7,400 for below ground.
1. do these quotes sound reasonable? (there is a $200 fee included to get to my property)
2. is it worth the extra money to put the tank underground? I have plenty of room.
Downside to above ground is the possibility of a tree falling on it as best I can tell. Downside to underground is the additional cost...which is affordable.
Thank you!
I'd get two more quotes. Around here you can rent a 500gal tank for $150-300/yr. 500 gal tank new costs CDN$4,500 retail
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
Ford 3600 Tractor (A54865)
Ford 3600 Tractor...
40' CONTAINER (A51244)
New/Unused SD Lanch SDLL50 Mini Skid Steer (A54865)
New/Unused SD...
