aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
You have to have vacuum for long enough to bleed all of the air out of the expansion chamber, otherwise its just putting out air (or a weak air/propane mix), not enough to start a motor on.I have a 10k electric start generator that starts after approx. 3 seconds of cranking. Earlier this year I used it and I turned off the LP and let it run until it quit, to see what would happen.
Generally I would leave the LP on and just switch the key off and then shut the LP tank off.
But then the next time I needed to run it, it cranked and cranked and cranked. It finally started after a dozen or more 5 second bursts of cranking. Now I just shut it off and then turn the LP off. Makes no sense to me why it does that but it does.
Aaron Z
