LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,777
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I like propane powered gas engines.
One reason many of the dual fuel units start on gasoline then switch is to get the coolant warm enough to run the vaporizers for the propane.
All the propane engines I'm used to used a liquid draw from the tank to the vaporizer with engine coolant as the heat source for the vaporizer.
Most automotive applications do not have enough vapor available until the coolant is warmed up for the vaporizer to function well.
Many of the older propane powered tractors were difficult to get started in cold weather and had a long warmup period before they could be worked hard.
