Project ranger for older couple
   / Project ranger for older couple
Well update time.
Got the motor set in and hooked up one last time. Had to pull it before again cause I forgot the tranny lines. Got to put antifreeze in it. Only got a gallon of water. Had it running but I think she needs gas. Have to take apart the front u-joint cause I just pulled the tail shaft out before. Will need to be done this week
Thanks for the update.
No problem. Goto the truck running for the most part, tail shaft put back in now just need to get the shifter adjusted so it will shift properly cause it's so out of whack it won't shift into gear
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A55788)
2006 Chevrolet...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET (A51406)
2012 FREIGHTLINER...
Galvanized Livestock Gate (A55218)
Galvanized...
