Project ranger for older couple
   / Project ranger for older couple
Well update time.
Got the motor set in and hooked up one last time. Had to pull it before again cause I forgot the tranny lines. Got to put antifreeze in it. Only got a gallon of water. Had it running but I think she needs gas. Have to take apart the front u-joint cause I just pulled the tail shaft out before. Will need to be done this week
Thanks for the update.
No problem. Goto the truck running for the most part, tail shaft put back in now just need to get the shifter adjusted so it will shift properly cause it's so out of whack it won't shift into gear
(15) 6" X 2" X 41" TUBING (A54756)
(15) 6" X 2" X 41"...
CATERPILLAR HANG ON 71" WHEEL LOADER FORKS (A51406)
CATERPILLAR HANG...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
