Project Farm, counterfeit batteries.
   / Project Farm, counterfeit batteries. #31
I'd be worried about cheap Lithium batteries starting a fire.
I assume most of these fake batteries are coming from overseas. It’s tough to shut them down or sue them. If you do lock them out they just change the company name and keep going.
   / Project Farm, counterfeit batteries. #33
Companies like Alibaba or AliExpress don't seem to care.
E-Bay is a mess because they don't actually handle the merchandise. Still, they could prioritize quality if they wished.
Amazon has their Fulfilled by Amazon. If they mix products from different vendors, then it could well be a mess, but they would seem to have the most to lose if they're intentionally looking the other way.
Unfortunately, the packaging of some of the fakes looks very good.
They could do quality control, and randomly sample say 1 out of 100 products from each vendor, especially new vendors.
   / Project Farm, counterfeit batteries. #34
you don't need to desolder all of them generally if its an all series pack, its pretty easy to find the bad one, spot welding can be a bit of a learning process as well.
That was my original hope. I opened it up expecting to find a series pack that I could replace a bad cell or the whole set. Like @California's experience, the design had each cell individually embedded into the board with irregular tabs and measuring the voltages across the cells wasn't informative. I suspect that the board equalizes each cell, because the appliance, a Black&Decker "Flex" hand vacuum, runs out of juice, shuts down and then 30 seconds later has more juice, lather, rinse, repeat.
The board and cell integration was the most complicated that I have ever seen, although the board itself was a very low cost board. My apologies for not taking photos.
All the best,
Peter
The factory battery packs he cracked opened had chips and circuit boards in them. I think these are called BMS (battery management systems?). I think these control the charge rate, maybe slow it down for the last 10%, and help keep the batteries more equally charged. I’ve learned a lot of this from e bike forums which sone of the e bike battery packs can cost $1000 or more.
I suspect the fakes don’t contain this or if it does lower quality and that’s why they lack in performance.
   / Project Farm, counterfeit batteries. #36
all lithium cells, use a bms correct, what it does is charge each cell individually so they don't become "unbalanced" this can cause stress to the individual cell which can ultimately cause it to catch fire. the bms can also monitor the amount of current allowed, the temperature of the pack, and the voltage cutoff point so the cells don't go bad.
   / Project Farm, counterfeit batteries. #37
here is what the inside of my BD 20v 2ah pack looks like.Ignore the brown cell, it was used to replace the bad cell in the pack
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
John Deere 335 Round Baler (4ftx4ft) (A52128)
John Deere 335...
