prodigy brake controller
/ prodigy brake controller #1
bjess8
SOUTH CENTERAL ,PA
GRAND L3130
I have a prodigy brake cotroller not sure what model but I know it cost me
$150, anyway when I press on the brake the numbers get higher and I know thats ok but when I push hard on the brake the numbers get higher then I get a error message which reads oL does anyone know what is causing this?I am sure the message means over load but it never did it before until this week when I used the dump trailer.any help would be appreciated.thanks
/ prodigy brake controller #2
Check all the grounds on the trailer. I would also check the entire wiring and the magnets. To make sure your trucks wiring is ok, hook up to a buddies trailer and check things out. You don't even have to tow it, just back up close and hook up the plug then try out the brakes.
Chris
/ prodigy brake controller #3
You can get all the manuals in PDF format here:
Tekonsha
/ prodigy brake controller #4
Do what Diamondpilot said, this will rule out 50% of the possible causes.
/ prodigy brake controller #5
I'd call or email Tekonsha. They replied to me in a few hours and told me exactly what to do to diagnose the problem I had. Took 5 minutes to fix it out once I knew what was wrong.
ok thanks for all the advice.:)
2022 EZ-GO ELITE...
3ft Teakwood Cowboy (A65583)
3ft Teakwood...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2005 International 4300 Rollback (A62613)
2005 International...
2008 Mazda 5 (A62613)
