prodigy brake controller
/ prodigy brake controller #1
bjess8
SOUTH CENTERAL ,PA
GRAND L3130
I have a prodigy brake cotroller not sure what model but I know it cost me
$150, anyway when I press on the brake the numbers get higher and I know thats ok but when I push hard on the brake the numbers get higher then I get a error message which reads oL does anyone know what is causing this?I am sure the message means over load but it never did it before until this week when I used the dump trailer.any help would be appreciated.thanks
/ prodigy brake controller #2
Check all the grounds on the trailer. I would also check the entire wiring and the magnets. To make sure your trucks wiring is ok, hook up to a buddies trailer and check things out. You don't even have to tow it, just back up close and hook up the plug then try out the brakes.
Chris
/ prodigy brake controller #3
You can get all the manuals in PDF format here:
Tekonsha
/ prodigy brake controller #4
Do what Diamondpilot said, this will rule out 50% of the possible causes.
/ prodigy brake controller #5
I'd call or email Tekonsha. They replied to me in a few hours and told me exactly what to do to diagnose the problem I had. Took 5 minutes to fix it out once I knew what was wrong.
ok thanks for all the advice.:)
Gravely Field Cultivator Attachment (A65640)
Gravely Field...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
70in. Skid Steer Root Rake (A65640)
70in. Skid Steer...
