Problems with my Ford F-150
   / Problems with my Ford F-150 #31
Another vote for a bad coil. I changed all of mine and the plugs on my 2002 5.4 at about 80,000 miles. Had the same symptoms down to the got worse with rain and humidity. I bought some aftermarket coils and they are still going strong at 110,000 miles.
Guess What! It was the COP #6, he moved it and the problem moved and he did other stuff to prove he got the right one.
$145 and I'm off to go pick it up as soon as my wife can haul me to the shop!
Thanks to all for all the great advice.
I have no other COP experience, but I knew it was missing, it felt like it was missing, and here it is, it was missing!
PS - I got WAY better advice here on TBN than on the F-150 online forum. TBN Rocks!
Thanks again,
Be well,
David
   / Problems with my Ford F-150 #33
My 2001 5.4 in my sd same thing. Bad cop x2 and bad boots x1. The boot generally will break down and let water in around the plug and get arcing. I got 8 tested cop's from a scrapyard for 10$ each with good boots and keep them for spares.
   / Problems with my Ford F-150 #34
Thanks again,
Be well,
David
If it happened once, it's probably going to happen again. I had 3 COPs modules go bad from 60,000 thru 100,000 miles on my 2001 F150 with the 4.6L Triton V8.
   / Problems with my Ford F-150 #35
I have had 6 F-150's with 5.4L's, my dad has had 4 F-150's and 3 Expeditions with 5.4L's, and my BIL has had 4 F-150's and one Expedition.
Me and my dad have never had a single one go bad. My BIL has had 2 go out total. My buddy down the road has a E-250 with 160,000 miles on it and the 5.4L and he has had 3 go out at different times.
They do go out but the nice thing is they do not leave you stranded like a old coil and rotor setups.
Chris
   / Problems with my Ford F-150 #36
Bigfoot, I LOVE the new Avatar! :thumbsup:
PRICELESS!!!
David
Thanks. :) I thought it was about time. I've been on here for 3 years without one. Did a search for "bigfoot" images and found it. It was calling me! The name of the drawing was "Redneck Bigfoot." :laughing:
Glad to hear that you found your truck problem. :thumbsup:
   / Problems with my Ford F-150 #37
hmm.. havn't had to deal with a COP issue.. but am converting just about everything newer I have to diesel as fast as I can.. anything I have that is gas, eventually, will be an antique tractor.. :) No COP.. only points.... :)
soundguy
soundguy
I suspect my next will be a diesel.
One of my buddies got a used diesel Expedition and he said it get better MPG commuting into DC than most of the smaller cars he used to drive.
But this F-150 has been a great truck and I suspect it has "farm use only" plates in its future...
David
   / Problems with my Ford F-150 #39
Havent read through all this yet. First thought is a spark plug is bad or has a crack inthe porcelin so its shorting out. Or a trully faulty O2 sensor will act like you have no power like that and will just come and go. My ranger had one go out (1990 model) and when it did it had no power, and would roll black smoke like a deisel under a load.
Read thru all the posts and saw you said it gets worse in the rain, was deffinitly thinking coil or plug then! Glad you got it fixed.
Me too sir! Me too!:thumbsup::thumbsup:
David
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
LOT LOCATIONS (A51222)
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
