Problems with BX24 and my hill!
   / Problems with BX24 and my hill! #1
dlinde31
I purchased a BX24 this past summer with the intent of a little yard work, but my biggest reason for getting the machine was for blowing snow on my driveway. I should say STEEP driveway! This is the way I have my tractor set up...
I have Kubota's 50" snoblower on the front
Wheel weights on the machine
I kept the backhoe on the rear
We just got 3 inches of sloppy snow and it had problems slipping, even with the wheel weights and backhoe still on the machine. I also put front chains on the BX24.
Questions? Can you put rear chains on the BX, I have tried but there seems to be no clearance? Would taking the backhoe off help in anyway? Should I keep the backhoe on and try adding more weight to the front somehow?
Any suggestions or comments would be great!
Thanks, DDL
   / Problems with BX24 and my hill! #2
I would take the backhoe off, it is too bulky to move around. I found that bar tire is better in snow, what type of tire do you have on yours right now? I also filled my rear tires with calcium. occasionally, I encountered some sliperage but this is when I have a reason to use my lock diff.
   / Problems with BX24 and my hill! #3
Which tires do you have? I was told by dealer that Turfs are best in snow and have read that here in threads also.
He also indicated I could put chains on.
   / Problems with BX24 and my hill! #4
While I'm not in snow.. i don't see how a dimaond tread would be better than a bar tread in snow.. hmm...
soundguy
   / Problems with BX24 and my hill! #5
I agree that taking the backhoe off is probably a good idea. I have a couple other tractors aside from my BX, and I've plowed snow with them both. The one with turf tires with chains is far superior to the one with bar tires. Chains are a must on my driveway, which is also ridiculously steep.
   / Problems with BX24 and my hill! #6
soundguy
I have used both turf and bar tread in the snow. The bars are better if you are actually driving thru deeper snow (pulling the kids on sleds, checking on the cattle, etc) or if you are pushing snow on a gravel driveway.
The treads are equally as good, if not better on paved surfaces when you are pushing snow. They have more ground contact and the sipes provide a bit more edge traction, especially if there is some hard pack or ice glaze.
Since I tend to do some of both, I use the ag tread all the time.
My neighbor has turfs and a paved driveway. He has talked about chains too, but don't think he will need them.
If someone has used chains, will you please post the specifics about them so we can all benefit?
Thanks
   / Problems with BX24 and my hill! #7
soundguy
Snow tires on your car a soft rubber (that's why you don't run them in the summer) hot pavement will eat them up. Soft rubber grabs packed snow/ice better. The turfs are soft rubber, the R4's are very hard. R4's might do better in deep fluffy snow. But packed snow or Ice the turfs do better. Turfs also have more rubber on the road and more little sideways grooves to grip ice. They are also easier to put chains on.
There was a long thread I read here on the subject and someone replied he had a whole fleet of commercial tractors for plowing and he had turfs on all of them.
   / Problems with BX24 and my hill! #8
There are also different thread patterns for turfs.:D :D
Thanks for the quick replies.
I do have the R4 treads. I thought that they would be the best option. Going with turf tires seems like a weird way of thinking? But if it works, I would be more than willing to try it. I believe that no matter which tire I go with, chains will be neccessary. I have put a set of old chains on the machine, but am worried that they will "slap" when traveling and eat up my rear fenders.
Just a couple concerns.
Thanks, DDL
   / Problems with BX24 and my hill! #10
2-link chains on the rear tires, which should be able to mount tight to the tire, would be your best bet.
I just installed mine yesterday and no tensioners are even necessary.
Chains and a foot planted on the diff lock should get you through anything the tractor is actually capable of navigating.
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
