Problems with BX24 and my hill!
   / Problems with BX24 and my hill! #11
mswlogo said:
Which tires do you have? I was told by dealer that Turfs are best in snow and have read that here in threads also.
He also indicated I could put chains on.
The bar tire has less contact surface then turf tire therefore you get more pressure per square inch and this is waht enable you to track better in snowy condition.
   / Problems with BX24 and my hill! #12
dlinde31 said:
Thanks for the quick replies.
I do have the R4 treads. I thought that they would be the best option. Going with turf tires seems like a weird way of thinking? But if it works, I would be more than willing to try it. I believe that no matter which tire I go with, chains will be neccessary. I have put a set of old chains on the machine, but am worried that they will "slap" when traveling and eat up my rear fenders.
Just a couple concerns.
Thanks, DDL
I was also told you need special (more expensive) chains for R4's because "normal" (cheap) chains will slip into the grooves. If they do they may get loose on you.
The thing to think about is when you are clearing snow you are usally working on the area you have just cleared and on packed snow, ice or slush where turfs do better. If you wanted to ride on top of the snow and skip the plowing you might be better with the R4's.
   / Problems with BX24 and my hill! #13
Not true. If the chain is properly installed, the cross chain should go over the tire tread on the R4, not between the treads. How do I know? I have R4's installed on my BX 24. Make sure you take the wheel off the tractor to install or you will be pulling on chain forever. The two link spacing here (26X12x12)will fit between/over each lug of the R4 with no chain slap and no tensioners required.
   / Problems with BX24 and my hill! #14
So why in the link do they show the "more expensive" chains on the R4's and the cheap ones on the Turfs? Although neither will exactly break the bank. I guess just a cooincidence. They sure do seem to go on nicer on turfs though.
   / Problems with BX24 and my hill! #15
Who Knows? I was responding to the concern about the chains not being compatible with R4's. Note the chains are not embedded between the lugs of the R4 where they would be useless. To be effective, the chain must cross the lug and make contact with the ground for traction improvement.
   / Problems with BX24 and my hill! #16
Seems like most agree that turfs will be a better all around tire unless you plan to "drive thru" the snow instead of "push" the snow.
We don't get a lot of snow in the Midwest, but when we do it is usually heavy and wet. Other than that, it is usually with some degree of ice or sleet. The turfs definitely work best on the ice/sleet as compared to the ags.
In the heavy wet snow (14 inches), I would bog the engine down with a nice plume of black smoke out the exhaust before I would lose traction pushing snow.
I can't imagine needing snow chains if you properly manage the snow conditions. The only time I have seen pictures of someone getting "stuck" is when they were sitting in a foot and a half of snow. How in the world do you get yourself in that situation in the first place?
I'm gonna need some pictures before I listen to the "chains" are necessary theory.
Guess I just started the "show me you're stuck in the snow" pictures thread.
   / Problems with BX24 and my hill! #17
I have a set of chains for my BX,easy to install if you have a cheap floor jack,most of the time I do not think they are worth the risk of ruining the hyd. lines they run so close to.If you use them you must keep them TIGHT,no loose ends, secure ends to main side chains.If you use 4 wheel drive the only time I could see that it would be nessary,ice on your black top hill under snow.
   / Problems with BX24 and my hill! #18
Hi to all. I have both, the turf and the bar (industrial) tires. I have pushed snow with the turf and spun all over my driveway (the treads get filled with snow and won't clear out) After installing chains and adding weight (filling tires with windshield washer fluid) I scratched my interlock drive. I then installed my industrial tires (filled with washer fluid) and now I can drive over a snow bank and go where I would not even have dared. My vote is INDUSTRIAL !!!
I live in Ontario and I know my snow!!
   / Problems with BX24 and my hill! #19
If you go with chains, the way I put mine on my wheel horse is I air the tire down some and put the chains on as tight as possible and then refill with air they will be so tight that they can't slip or slap.
   / Problems with BX24 and my hill! #20
What model Wheel Horse do you have? I love Wheel Horses.
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
