Oil & Fuel Problem with starting JD 2305
   / Problem with starting JD 2305 #1
FloydB
Eugene, Oregon
John Deere 2305
When I last used the tractor (yesterday), ran fine. Today, went to start it and it ran for about 2 seconds then shut off like it was out of fuel. It has 7/8 tank of diesel. I primed the fuel pump and tried to start again. Same results. Have tried at least a dozen time and tractor will not stay running longer than one to two seconds.
   / Problem with starting JD 2305 #2
Drop fuel filter and see if there is water in the bowl. Change filter if there are a number of hours on this one.
Look for fuel blockage as well as check that the fuel shutoff solenoid is working.
:welcome: to TBN
   / Problem with starting JD 2305 #3
   / Problem with starting JD 2305 #4
:welcome:
To the forum. I sure wish that Oregon had beat OSU.
   / Problem with starting JD 2305 #5
mdd
They could have ... if.... :D
   / Problem with starting JD 2305 #6
Is the pto switch turned off?
   / Problem with starting JD 2305 #7
It's more likely to be the diode if it's start and dies almost immediately.
It was the PTO lever that was in-between positions. Easy fix to a dumb problem that I should have checked first. Thanks to all.
2010 Mitsubishi Fuso FE84D 16ft. Box Truck (A48081)
2010 Mitsubishi...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2015 Bandit 990 XP Trailer Mounted Wood Chipper (A50860)
2015 Bandit 990 XP...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A48082)
2005 Northwood...
