Problem with Lift Tilt Dump...
/ Problem with Lift Tilt Dump... #61
Since I don't have a set up like yours so I can't say for sure, but the accummulator when it gets its pressure and builds up seems like it might have a check valve[whether piloted or manually released] that holds that pressure and when you cut off the machine it relieves the pressure on the check valve. If it has a check valve then that check valve could have something holding it open and letting it just pump oil straight through it and back to tank. If it has a check valve and it is stuck open then that would cause the problems that you are having. Just thinking out loud without looking at the system that you have, I'm probably wrong about that thought but then again I might be right, and then again who knows [Terry].
I think you are right. I did pull the check valves and no joy. I also have this high pressure filter that is in line with a meter on it that tells if the filter is in good shape or bad shape. This also may be the culprit. Talking to Terry today.
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
Informational Lot - Financing (A63688)
Informational Lot...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
