problem with Kubota L48 starting
/ problem with Kubota L48 starting #1
l48ed
ashaway, ri
l48
I have a 2008 or 2009 Kubota L48 and it is intermittently not starting. The battery is strong and it cranks well. I had Kubota repair guy at it and he was unsure of exact problem. He told me that he replaced a fuse that "should not have been involved with the starting circuit" but after he replaced it, the engine started. He seems to remember he replaced the "working light" fuse. I just spoke to him and he thinks it may be that a fuel solenoid is not getting enough juice to pull properly. I don't have manual for engine or wiring diagrams. Can anyone tell me if they agree with diagnosis and where exactly this solenoid is located. Also, where can I download shop manuals and wiring diagrams. Thanks much
/ problem with Kubota L48 starting #2
:welcome:
/ problem with Kubota L48 starting #4
I had a similar problem on my L39 and the kubota dealer said it was a bad connection in the fuel solenoid wiring. It took 3 trips to dealer for them to finally find and "fix" the problem. They either replaced or re-crimped the connection and no problems since. Phantom wiring problems are hard and frustrating to find. Be sure to check all wiring where you have a connection to chassis ground. A shop manual with wiring diagram will show all those points as well a the fuel solenoid circuit. Let us know what you find. Good Luck!
/ problem with Kubota L48 starting #5
Welcome to TractorByNet from Tennessee.
/ problem with Kubota L48 starting #6
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
(3) Corral Panels (A66408)
(3) Corral Panels...
2022 EZ-GO ELITE...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
