PROBLEM WITH JOHN DEERE 755
/ PROBLEM WITH JOHN DEERE 755 #1
rch56
Sandusky, Mi
john deere a
WE JUST PURCHASED JD 755. TRACTOR WILL START BUT ACTS LIKE ONLY RUNNING ONE 1 CYLINDER. SHAKES TERRIBLE, AFTER 2 TO 3 MINUTES PICKES UP OTHER CYLINDERS AND RUNS GOOD. CHECKED FILTER, FUEL LIFT PUMP TO INJ PUMP.GOOD FUEL FLOW TO INJECTION PUMP. ALSO NO THROTTLE RESPONSE TIL PICKES UP OTHER CYLINDERS. THINKING IF BAD INJECTOR OR PUMP IT WOULD NOT RUN RIGHT AFTER WAITING 2 TO 3 MINUTES. WHAT SHOULD I CHECK NEXT
/ PROBLEM WITH JOHN DEERE 755 #2
Makes sure the all the fuel system lines are tight. It sounds like your getting air in the fuel system somewhere and the engine runs correctly once it clears the air out.
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2023 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2023 WEILER K560...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
CAT D5N Straight Blade / C-Frame (A68134)
CAT D5N Straight...
40' 6 Door Shipping Container (A68183)
40' 6 Door...
2009 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
