Problem with Hydraulics
/ Problem with Hydraulics #1
fcamillieri
Chester, NH
CK20HST
The lever to run the BH doesn't stay engaged. It used to but now I have to use a bungee to hold it in. Is there something wrong or an adjustment I can change?
Thanks,
Frank
/ Problem with Hydraulics #2
I don't get it? The backhoe doesn't stay engaged? Huh?
I'm probably just having a dense day..
/ Problem with Hydraulics #3
Sounds like he has rear remote hydraulic connections and the valve that controls the flow is no longer staying in it's ON detent position.
Will it not stay in either the A or B position or just the A position?
/ Problem with Hydraulics #4
There is an adjust for the detent pressure. My CK 25 went the opposite way and it was so hard to move that I bent the lever. Works perfect after I tweaked the detent spring pressure.
Won't stay in either position. I'll look for a detent adjustment.
Thanks,
Frank
(10) New CATERPILLAR Keys (A65579)
(10) New...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
1999 Volvo Manure Truck (A62613)
1999 Volvo Manure...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
