Problem with Hobart 140
   / Problem with Hobart 140 #1
CharlieTR
NE TX
Long LongTrac
In the Summer I bought a new Hobart 140 Mig/FCAW. I only use Flux Cored.
Used it often with no problems. Now, I think for the first time, I turn it to max output of 4 for the power, and it sputters and spits and outputs a week fizz of an arc. The arc even sounds week! Makes the uglest welds I ever made.
The machine sound be when just trying to feed the wire. It wines and moans trying to feed the wire. Anyone have an idea what I should look for?
Thanks,
Charlie
   / Problem with Hobart 140 #2
What about the simple things like proper drive roller/wire type and size. Tension? Do you have a good ground?
Also, you need to reverse polarity for mig.
Hobart is a quality machine so it's either a lemon or you have missed something simple. It's the simple things we tend to overlook.
   / Problem with Hobart 140 #3
Check the power going to the welder. Are you using an extension cord.Does it weld properly on lower settings. This welder has a 1 year warranty.
Bill
   / Problem with Hobart 140 #4
bad tip? does it feed okay when your just running wire and not actually trying to weld?
   / Problem with Hobart 140 #5
I am also go with "mroldstyle" view....You should first check it that it just give the actual output when you running wire or not.
   / Problem with Hobart 140 #6
It sounds to me like it is either a bad contace tip, or a clogged/worn liner. It might also be that you have the gun cable bent too much.
   / Problem with Hobart 140 #7
I'd remove the tip and verify it is feeding smoothly and also check the dc voltage output. Should be between something like 18 v to 25vdc or so at the various settings.
Most likely a tip, dirty rusted wire. Doesn't take much to stop 20 volts.
Pop up camper (A51694)
2016 R and R Products 331 LP Reel Mower (A51691)
2016 R and R...
23169 (A50324)
23169 (A50324)
HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
