problem with Cub Cadet 48" riding mower
   / problem with Cub Cadet 48" riding mower
The belt was just a month, at the most two months old. I plan to pull the deck off and check for any bearings that are worn.
Is there any chance that the pulley's themselves are out of line?
   / problem with Cub Cadet 48" riding mower #13
My JD L130 liked to throw belts and the reason for the problem was the idler pulley bracket failed. It literally broke off in my hand when I was putting the belt back on. $5 or $6 for a new bracket and an equivalent in gas to and from the dealer solved the problem...so far.
   / problem with Cub Cadet 48" riding mower #14
what model is it??? my FIL has a 21XX (cant remember the exact model) Cub Cadet with two belts on the ~50" deck (one on the deck and one to go to the engine) a few weeks ago it shredded the deck belt, the cause was the tensioned freezing up, it was bolted to the deck, no double nutting or anything, I replaced the bolt with a longer one, put on 2 washers above and below the tensioner arm and double nutted the bolt that holds everything together. it should not have that problem again.
Aaron Z
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 5ft Quick Attach Mixer (A57454)
New/Unused 5ft...
Pickup Truck (A59230)
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
