problem with 4210
/ problem with 4210 #1
john4210
Harwington CT
hi this is my first time posting but ive watching this forum for about a week..
i have a 4210 with a 420 loader 47bh..
this weekend i went to put my bigger bucket on the backhoe (24") and noticed that the grease fitting on the end of the boom was missing ,after some inspection and a little break clean, i found that the fitting broke off.. must have been from the concrete sidewalk we dug out last week.. my ? is how would you guys get the old remaing part of the fitting out?
my second ? is also at the same time i went to adjust my steering wheel to get onto the seat and the lever will not move at all .. is the steering wheel lever a comon problem..
The machine has never been cleaned and primarly works in masonary situations .it is very dusty from concrete saws and other things..
On the other note this tractor has been put threw hell in the first 6 months we have owned it and it just keeps going ..very nice machine so far..
Allen Yard
Stonebridge construction
/ problem with 4210 #2
I don't know anything about the steering wheel on that tractor, but as for the grease fitting . . . do you know whether it's pressed in or screwed in. If it's screwed in, a tiny eaz-out or even a tiny screwdriver jammed into it should work. If it's pressed in, I'd try screwing a small screw into it and then pull it out.
/ problem with 4210 #3
Steering wheel levers on the tens gets pretty hard when that plastic housing gets hot from the heat and everyone we have had does stick.
/ problem with 4210 #4
(Steering wheel tilt mechanism) - Mine is pretty dusty at times as well from all the earth I've moved with it... I've found a good cleaning (hose it down well) loosens it up - that and running it through the range of motion several times to get it loosened up. WD40 or some other product may help you get it moving, but it will attract dust and dirt in there... Just give the poor tractor a bath! /forums/images/graemlins/smirk.gif It's earned it. /forums/images/graemlins/grin.gif
/ problem with 4210 #5
My steering wheel lever on my 4310 locked up at about 50 hours. The shop said they had seen the problem before and the fixed it quickly.
/ problem with 4210 #6
I liked the tilt steer on my 4300 more with the rubber boot and the lever you would pull out and adjust the wheel at any position. Kind of miss it.
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
2014 Ford Focus Sedan (A61574)
2014 Ford Focus...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
2005 Ford F-350 Crew Cab Pickup Truck (A61573)
2005 Ford F-350...
