Problem starting a Ford 8N
/ Problem starting a Ford 8N #1
JimsD
Ford 8N
I have a Ford 8N which is stubbornly refusing to start. When pressing the start button, I hear a click in the starter motor but nothing else. Not sure where to go from here. Anybody got suggestions or had a similar experience?
Cheers. Jim
/ Problem starting a Ford 8N #2
weak battery, bad or corroded connection in wires is where I would start.
Also could be bad spot in starter, or silenoid.
Would be helpful to know if its 6v or been converted to 12v
The other thing I have done is boosted with 12v cabels directly on starter (not battery unless its another 6v vehicle). Make sure its in neutral and don't hold them on long. It will whirl over fast but should start easy if starter is good.
The other thing I usually do if I am having trouble starting my tractors is pull them with a truck to get them started and let them warm up a little so they start easier off the starter.
Not sure how mechanically inclined you are maybe you have already checked this stuff, But good luck!!!
/ Problem starting a Ford 8N #3
First thing I would do is check the battery and make sure it has juice in it, make sure the terminals aren't corroded and the connections are tight.
If the battery is not the problem, then as previously stated it might be the solenoid or the starter. Google for additional help on that...
/ Problem starting a Ford 8N #4
yep.. check battery volts when starting.. if they stay hight, then start checking bat terminal ends and connections including ground strap to rusty? painted? metal..
next connections at soleneoid, and then starter.
also.. just a fyi.. a foot ont he clutch means you don't have to spin trans shafts around in gear oil = more starter speed.
post back
soundguy
2012 Dodge Grand Caravan Van (A61574)
2012 Dodge Grand...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2011 Porsche Panamera Sedan, (A61574)
2011 Porsche...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
1042 (A60430)
1042 (A60430)
