3-Point Hitch Problem lowering 3 point
/ Problem lowering 3 point #1
JBTB
Cedar Creek Texas
JD 1020 JD R
I was doing some work and a tree branch randomly pitched up from the
right front wheel and entered the operator area on my JD 1020. It bent the metal guide to the 3 pt hitch lever and also moved the 3 position switch under the seat area.
I did not know that switch existed much less what the position had been. Not
sure what it does.
I've straightened up the metal guide and the lever will move the full range but
the 3 point will not move to its previous low position. This is true if the unknown switch is in any of the 3 positions.
Can someone please tell me what the switch does and does anyone have
any thoughts as to why the 3 pt behavior has changed?
THANKS
JBTB
/ Problem lowering 3 point #2
The 3 position handle under the seat is the load & depth control
D = depth
L/D is a setting in between L & D that is less sensitive than L
L = load.
For any operation other than plowing the lever should be set in "D"
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
L6060 Kubota For Sale
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
