Problem getting 2 bottom plow to work correctly
/ Problem getting 2 bottom plow to work correctly #1
kastaway
Glenwillow, Ohio
Kubota
Bought a used JD 2 bottom plow. Tried to adjust over and over with no luck. At times it works for a short distance, but when the second plow turns the dirt, it just flops back into the trench. Tired everything.
Cat 2 , was a 3 bottom, 3rd taken off, 12". Tire fits in furrow. It rolls the sod which is held together, and then just falls back in furrow. New to plowing
It is L45 Kubota, not sure on size, but a Cat 1 3pt hitch
/ Problem getting 2 bottom plow to work correctly #5
Look on You Tube. Search for using a bottom plow.
If it is a 2-14 you need to set the depth of the front plow at 7". If it is a 2-16 set the depth at 8". Place a board on the ground and run your right tire up on the board at the height needed based on the plow size. The bottom of the plow should be level with the ground while the front tire is up on the block. This is a starting point. Once you get the front plow set then adjust your back plow with your top link. You will need to run at a speed to turn the sod over. If you have draft control on your tractor adjust it to keep the plow in the ground. If possible you may be able to add a depth gauge wheel on the back of the plow to help with depth control. A picture would help. Keep us posted as to your progress.
Will go work at it. Could it be that the colters are not down enough Now they are about 3" away from the plows
Thanks for all the help. I lowered the colter wheels closer to the plow and its working pretty well. Thanks again.
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
240 Massey Ferguson Tractor (A61165)
240 Massey...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
