Probably IP Gear (Control Sleeve) Failure
   / Probably IP Gear (Control Sleeve) Failure #31
Congrats..
Theres nothing like THAT FEELING, when an engine roars to life..
& theres nothing like THAT FEELING when it doesn't, after working on it for days..
Glad I could help..
   / Probably IP Gear (Control Sleeve) Failure #32
Glad to hear that you are up and running again. Also noticed that you added yourself to your own list in the Kioti stickies.
I really need to re-write that sticky. We have learned much in the last 5 years. I also need to do a photo writeup on the repair. Replacing the IP control sleeves/gears is quite easy (and easy to screw up) but well covered by neches. But there were some other tricks worth documenting. In all, I think I had the IP in and out about five times so I got pretty good at it.
   / Probably IP Gear (Control Sleeve) Failure #34
Easy huh?? If it was "easy" it wouldn't have taken you 5 tries & countless email questions to get it right..
& to be honest, you got "lucky".. things could have gone very wrong on any one of your "tries"..
You got VERY LUCKY that #4 DIDNT pump.. it could have gone the "other way".. very easily.. the engine could have flooded w/ fuel & the engine rpms could have been uncontrollable.!!! leaving you with a large boat anchor w/ 4 wheels & a big hole in the side of the engine block..
I know you feel a sense of pride & accomplishment, as well you should.. but please stop saying, "Its easy".!!!
I owe thepumpguysc a big debt of gratitude for his prompt and spot-on answers to my many questions, even when I did not understand his answers at first. But replacing control sleeves was easy and I did it correctly the first time. The subsequent "tries" were needed to find and correct a pre-existing assembly error in a delivery valve. If I had TPG's expertise I would have spotted this error on "try" #3 when I first removed the "bad" delivery valve. But it took two more "tries" before I pulled a good delivery valve for comparison. During tests to isolate the problem the injector hard lines were not installed so the engine could not run or become uncontrollable; not having a test fixture, I had to use the engine to test the IP.
   / Probably IP Gear (Control Sleeve) Failure #36
Glad you have it running, should be good to go for a long time.
I mowed my field today with the newly repaired IP. Everything worked fine although I did notice that the engine now idles at 1100-1200 RPM compared to 800-900 in the past. To me, this supports my recollection that the #4 deliver valve was mis-assembled (gasket in wrong place) when I got the tractor in 2009. Considering that the engine paint was still intact on the injector hard lines/nuts, the DV was probably mis-assembled at the Doowan. I really wish I had taken more photos vs relying on my memory. Regardless of the cause, all is well now.
This is the first time I mowed without the loader installed. The tractor was more agile and I could get closer at the turns but it was not significantly better than when the loader was installed, IMO.
For some time I noticed the fabric on the OE coolant hosed was getting ratty and the hoses were soft in places. I had ordered new hoses as backup some time back so I installed them and changed coolant after I finished the IP work.
In earlier posts I said replacing control valve sleeves is easy. I would caveat that by saying it was easy ONLY after CAREFULLY studying the excellent material provided by neches.
   / Probably IP Gear (Control Sleeve) Failure #38
Congratulations on a job well done.
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2015 Freightliner Cascadia SLEEPER (A58017)
2015 Freightliner...
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
Deere 35G (A53317)
Deere 35G (A53317)
