priming L 3350 Kubota
/ priming L 3350 Kubota #1
auroco
Working on a neighbors Kubota L 3350, found the fuel filter full of water. now can not get it primed. Anyone know tricks for the tractors?
/ priming L 3350 Kubota #2
To start open bleeders, you can fill filters proir to installation for less frustration. There are times more then one injector needs to be loosened at once but with most systems you can only do one at a time.
/ priming L 3350 Kubota #3
Hope this helps. On my Grand L3130 The procedure indicates to
1:eek:pen the fuel cock on the filter,
2:Open the air vent cock on the fuel injection pump.
3:start the engine and run for about 30 seconds and then stop the engine, 4:close the air vent cock
This is the procedure I have used after replacing the fuel filter.
Thanks for the tips, I'll try them this week end.
Turns out the problem is a cloged shut off valve at bottom of tank.
/ priming L 3350 Kubota #6
How did you find it?
Lot 602 (A62613)
Lot 602 (A62613)
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
