Pricing for JD2030 w/pto clutch issues?
   / Pricing for JD2030 w/pto clutch issues? #1
jd2030
John Deere 2030
JD2030 has pto clutch issues
What is value of this tractor?
   / Pricing for JD2030 w/pto clutch issues? #2
The value of any tractor has to be based on more than the condition of the PTO clutch. You would need a lot more information than that.
   / Pricing for JD2030 w/pto clutch issues? #3
While paying attention to what Harry said, factor in the cost of splitting the tractor and replacing the clutch if it comes to that. That is generally the way the clutch is accessed. Of course it could be a simple adjustment. All in all you've given insufficient data for an estimate.
   / Pricing for JD2030 w/pto clutch issues? #4
Welcome to TBN
Which type pto clutch(dual stage or hyd ind)?
   / Pricing for JD2030 w/pto clutch issues? #5
without any info I would have to assume from a buyer's point it's a parts tractor.
Understand
I have looked through this site for years and this is my first post ever for any forum of this type so more information:
Have owned this tractor since 2003 and is a great tractor. It is 1973 serial#185489T
The engine (4 cyl 219 diesel) was rebuilt just before I bought it-the tach worked but hour meter did not-I replaced the tach and has 2810 hrs.
8 X 4 transmission; hydraulic/live independent pro; 2 rear remotes
Have used this tractor to do commercial mowing & hay cutting for the last 15 yrs w/many of those logging 10-15 hours/day
Tires are 70% or more 16.9-28 rear 7.50-16 front
Front JD weights (2)+bracket 300#
JD roll-guard aluminum canopy which is pretty bent up(angle frame OK)
Metal is all pretty straight. Will try to post a couple of pics in a bit. Dealer says 1500-2500 for repair and my better half says I should spend that on new or newer one than repair this one!
Pics of the 2030
   / Pricing for JD2030 w/pto clutch issues? #8
You might find that repairing it now and fixing your roll guard will net you a much more than selling as-is
For someone with a shop and equipment to split this tractor and repair it could be a great older machine for your farm
   / Pricing for JD2030 w/pto clutch issues? #10
You won’t get much for a broken 2wd, geared, no FEL tractor if you try to sell it as is. Buyers will lowball you, figuring the worst case scenario for repairs.
I would bite the bullet and repair it, but before taking it to the dealer, I would see if an independent shop might be a bit cheaper.
When you get the tractor back, you can sell it for a better price, or keep it and continue working.
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2012 Honda Accord (A50324)
2012 Honda Accord...
2011 Nissan Rogue Multipurpose Vehicle (MPV), VIN # JN8AS5MT4BW575593 (A50324)
2011 Nissan Rogue...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
