Price Check Pricing between dk40/dk45/dk50
/ Pricing between dk40/dk45/dk50 #1
Impschocok
Oklahoma
Not yet an owner
Hello all. I am getting close to a new tractor purchase. I would like to think that I have well educated myself and determined what would best suit my needs. I have just about settled on a dk45se hst with a fel, but I am curious as to the price differences people are seeing between the 40/45/50, similarly equipped. The specs are very similar with the exception of hp. In fact the specs state that the pto hp between the 45 and 50 is 1.5hp. I think one would find it very difficult to find a real benefit to that 1.5hp through most normal tractor work. Anyway I digress, my real question has to do with the pricing between these models. As a believer that you can never have to much hp, the 50 seems appealing, but if in reality the 40 will do all the same work, is one only spending extra money for a label of more power with the 45/50 when it might be better served on an implement. If I lined up these three models am I likely to them priced at a difference of only a few hundred dollars model to model, or a few thousand? There has to be a point of diminishing return here. Thanks in advance for all the feedback as it is genuinely appreciated.
/ Pricing between dk40/dk45/dk50 #2
The three versions of the tractor are truly identical in all respects other than decals and engine stroke/bore. The 40 has a 2liter engine, the 45 is bored out to 2.2liter and the 50 is stroked and bored to 2.4liters. Everything else is identical. Prices between the three seem to vary a bit. A couple of years ago it was as much as $2000 difference from 40 to 45 but I have also heard smaller figures though still over a grand.
Your points about relative differences in PTO power and more importantly in what work can be done are important. I haven't yet heard someone here with a 40 which they'd bought a 45 and no one with a 45 has claimed they wished they'd sprung for the 50. Loaders and 3pt lift are identical so the only real issue is whether the relatively small differences in PTO hp make a difference for you. The 40 runs 6ft implements just fine. Larger implements are much more expensive so the cost of moving up to run bigger implements requires both the premium for the extra hp and the much more expensive implements.
I've always argued that the 40 is the best bang for the buck. I've had one now for 4+years and have zero wishes for more HP. I'd buy the 45 in the cab version but only to make up for the A/C drag.
/ Pricing between dk40/dk45/dk50 #3
I'm in the process of buying a cabbed hst tractor to pull a 6' brush hog on 12 acres of grass (old hayfield). I've settled on the DK45SE, chose it over the DK40SE because of the air conditioning taking power to run. I got a price on the DK50SE yesterday, $2K difference from my local dealer. I think that's a lot of money for 1.5 PTO HP when everything else is the same.
$2000 does seem steep for the dk50 jump. That's kinda what I was afraid of. I wanted to make sure that I wasn't missing something other than the slight jump in hp to account for that much money. As I had said earlier, I had in my mind that the dk45 would be a good fit for my needs, but now I'm really considering the dk40 and taking my money savings into the implement world.
/ Pricing between dk40/dk45/dk50 #5
A DK40 with an extra $1500-2000 to spend on implements will get a lot more work done than by simply boring out the engine block to get 4hp.
/ Pricing between dk40/dk45/dk50 #6
Can you elaborate on how you plan to use the tractor? What pto type attachments will you be using OR do you know yet? In the tractor world, more is almost always better.......(with a grain of salt).:laughing:
I run a 6ft brush bull (Woods bush hog), use a 6ft. KK tiller, and have never had an issue. Granted, this may be very limited in comparison to what others use and/or need.
Actually, in the past 2 seasons of use, I run my brush bull around the 2000 to 2100 rpms (less than the 540 PTO speed mark calls for...) and I run in the M range. With the tiller, I'm in the L range and going slow. I've yet to have any problems w/ these attachments.
If you were getting a cab unit, I can see where the A/C may have a slight impact on the PTO but still not that significant? (again, not knowing what you are using w/ it??)
I agree w/ IT that the 40 is the best bang for your $$. Unless you are going to try and do some baling work where you may need more PTO hp, I think you'd be happy w/ the 40 and some nice implements.....just my opinion.
/ Pricing between dk40/dk45/dk50 #7
One of our Ontario members here got quotes of only $1000 more to go to the 50 from the 40. He went for the 50 which makes sense for that little money, but I suspect that specific dealer really wanted to move a 50 for some reason? My dealer quoted $1200 more to go to the 45.
An interesting fact as well, is that the 45 and 50 are about 5% more fuel efficient than the 40 according to the charts Kioti publishes.
Probably not a big deal for the 100hr per year user but over time the 45 or 50 would partially pay for themselves.
For me, the extra cost of the 45 or 50 was not an option so it was an easy choice to get the 40 and I haven't even turned on the pto yet in the first 58 hours so clearly PTO hp isn't a concern of mine. Could be for others though.
/ Pricing between dk40/dk45/dk50 #8
Without a cab my dealer offered the DK50 for only $1000.00 more than the DK40. I needed the extra PTO to run a baler so even a little more HP was a factor.
Timing is very important. My first tractor did not come in on time. I was not happy but my dealer told me the new rebates were even bigger. We cancelled the original order and reordered to take advantage of the better rebates. See if your dealer will tell you when the best rebates will be in effect.
Good Luck
/ Pricing between dk40/dk45/dk50 #9
That is far more realistic a price difference. To be honest though, it literally doesn't cost Kioti more than a few bucks extra to make the DK45 or DK50. They are identical in every respect except for how they bore and stroke the engine block. Different sized pistons must cost pretty much the same. The price differentials are just marketing driven. It might even be that Kioti "needs" to charge more for the 50 in order to get Kubota and JD shoppers to take it seriously, I don't know but it sure isn't in the manufacturing costs.
/ Pricing between dk40/dk45/dk50 #10
This is the same story as the CK line. The jump from CK27 to CK30 is only $700 but the jump from CK30 to CK35 is $2000. I'm with the OP, the more hp the better and I was willing too spend an extra $700 but $2000 more on top of that for very little extra wasn't worth it. I think it's going to depend on individuals and their preferences and how they value the premium over the life of the tractor.
If you don't mind me asking, what are you guys seeing for an out the door price on these models?
/ Pricing between dk40/dk45/dk50 #12
Interesting to hear that you are running a 6ft KK tiller with a DK40. I am trying to decide about the target PTO hp for my next tractor and the highest demand implement I have is KK TG72 tiller, which according to the specs needs 35 to 50 hp PTO. I would probably consider DK40SE HST CAB model my first option but have been debating also between DK45 or DK50 and Mahindra 5010 because of this tiller hp requirement.
/ Pricing between dk40/dk45/dk50 #13
I have a DK40se and run the 6ft KK tiller. No problem at all. Cuts old sod at about 2200 rpm in low range without breaking a sweat.
/ Pricing between dk40/dk45/dk50 #14
I run a 6' King Kutter II tiller on my DK 35 with no problem and its the older model/style DK 35 (before the DKse series) with 34 HP and 28.3 PTO HP.
/ Pricing between dk40/dk45/dk50 #15
Careful now, A/C in the cab is going to rob 5-7 hp, so if you're marginal to start, you may find you have to turn the A/C off to make it work. Not a big deal if it were a snow blower, but a tiller may be a different story. I'd start by looking at the DK45 and do some soul searching over spending the extra money on the DK50.
/ Pricing between dk40/dk45/dk50 #16
I do alot of loader work on hilly terrain. I would say that 24 hours of the 26 hours on the machine were loader work. [I have only had it for a few weeks, give me a break!!] In my case the $800 premium was worth it. If I could have gotten a 60hp unit I would have. So you have to be 100% honest with yourself in what you want. If PTO HP is what you want I would go with the 45 if you need drive HP for pushing or breaking out dirt then the more the better. The HST pump is in the 20+ GPM range depending on RPM and stroke. At 5000psi [relief setting] the pump requires 70 HP. CJ
/ Pricing between dk40/dk45/dk50 #17
No, the DK40 has plenty of spare power to run the tiller. We have guys reporting the DK35 (older version) has plenty of power. We have guys reporting that the DK40se can run the tiller through thick virgin sod at well less than PTO engine speed. Why raise a purely speculative concern that runs directly counter to established experience? Besides, I seriously doubt the A/C load is even 5hp much less 7hp, where did those numbers come from?
/ Pricing between dk40/dk45/dk50 #18
What is this about "20+ GPM" from the hydraulic pump? 16.8 GPM is the published figure if I recall correctly.
I spin my tires pushing into dirt piles or against trees while using a 41hp DK40se at less than PTO speed in four wheel assist. How exactly will extra horsepower help me?
/ Pricing between dk40/dk45/dk50 #19
My dealer. When I went through the process of buying my cab and deciding to either keep my tractor or trade for a cab tractor, my dealer cautioned me about A/C with the DK35 cab because they've had complaints about a lack of power while the A/C is on. They told me 5-7 hp and I'm pretty sure I've read that elsewhere as well, although I can't tell you exactly where.
Since I don't have a DK40 with 72" tiller, I can't say for sure, but the OP is concerned about PTO hp, more so it seems then first hand experience. With that in mind, the A/C is going to reduce what the OP considers the inadequate PTO hp of the DK40. Correct me if I'm wrong, but none of the other posters who've used a 72" tiller with a DK machine were also running A/C.
/ Pricing between dk40/dk45/dk50 #20
That is correct but when I run the tiller even breaking sod I don't need full horsepower. The 40 has reserve available. Besides, tilling is done spring or fall but almost never mid summer when A/C is likely to be used.
Based on my experience with a non cab 40, I would go with the upgrade to cab45 only if doing a lot of thick grass or brush mowing mid summer. As most of us only use 6ft mowers, and as grass is most difficult to mow in late spring or early summer when it is lush and thick, I'd suggest people really think through their intended tasks and how those intersect with A/C needs before making a decision. If you need max A/C in May you might want the extra HP but if your A/C needs are when grasses are dry then you could save the money or get an extra implement instead of spending a grand or two on 4 extra HP.
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
ACETYLENE AND OXYGEN BOTTLE (A68842)
ACETYLENE AND...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
