Pricing a 1968 Ford 5000 with loader
   / Pricing a 1968 Ford 5000 with loader #1
bnew17
Georgia
2001 JD 5310 w/ 542 FEL
Heres the situation on this tractor im looking at.
An older man, in his early 80's has a Ford 5000 with a front end loader on it. The tractor has 2100 hours on it. 8 Speed diesel with power steer. Ind PTO. The tractor has been parked and out of use for almost 2 years now. One day the man used the tractor , parked it,,,and 2 weeks later went out to use it and couldnt get it to crank. He Said some of the "fluids" were leaking and mixing together. The tractor will need to be worked on to get running again as it does not crank now but owner says the hydraulics work great, everything works great except what he mentioned about the leaking and the tractor not cranking. The tractors tranny was replaced 6 months before this. Also the back tires are Brand new and he has included a heavy framed disc harrow as a nice gesture with the purchase of the tractor. Not sure on the size of the harrow but there are 10 disc on the back and 8 on the front. Harrow has some surface rust that would need to be taken off and some of the disc would most likely need to be replaced. From reading this what would be a good price for this tractor and harrow combo!
   / Pricing a 1968 Ford 5000 with loader #2
Buying a dead tractor with oil in the water or water in the oil is risky. Shoot him a little above salvage value. $2500 3000 maybe for everything and hope it is a blowed head gasket and not a cracked block? Ken Sweet
   / Pricing a 1968 Ford 5000 with loader #3
I agree.. which fluids were leaking.. makes a big difference? if oil in water or water in oil.. might be an expensive lump of cast iron to deal with.
trans, hyds and diffy intermixing?
soundguy
The man selling the tractor is very old and kinda forgetful but he said he's pretty sure it was hydraulic fluid in the oil.
Keep in mind with quotes to factor in the 8ft heavy duty disc harrow
   / Pricing a 1968 Ford 5000 with loader #5
hmm.. hyd fluid in the crankcase oil on a 5000... what kind ( if any? ) power steering setup does it have?
soundguy
I know for sure it has power steer
   / Pricing a 1968 Ford 5000 with loader #7
could just be the front seal in the power steering pump which is very common and would need to be fixed before using the tractor i would say its worth atleast 5000 which is about 1500 over salvage
   / Pricing a 1968 Ford 5000 with loader #8
that pump might have to be replaced if the housing is cut.
soundguy
   / Pricing a 1968 Ford 5000 with loader #9
I think you can find a pretty good running 5000 for $5000.
   / Pricing a 1968 Ford 5000 with loader #10
ditto that. working 5000 for 5g's is about right. bout' what I paid for mine.. twas ugly.. but started and ran ok and everything worked...
soundguy
1999 UTILITY 102" X 53' REFER TRAILER (A51243)
1999 UTILITY 102"...
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
