rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,455
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
</font><font color="blue" class="small">( I thought these units came with the necessary connections to run all these attachments. )</font>
The attachments for the most part should come with hoses and hydraulic quick disconnect fittings, but the remote valves on the tractor would not be included.
</font><font color="blue" class="small">( If not, I really need to consider this issue when I make my purchase, new OR used. )</font>
Yup.
</font><font color="blue" class="small">( I will eventually need a BH (after I buy a friggn' tractor) and I assumed that it was self contained and ran off a PTO. )</font>
It could be that way - or not - depending on the specific backhoe brand and model. My BL4690B backhoe for my B2910 came with a PTO pump as part of the kit. On the otherhand the BH90 for larger tractors probably doesn't (runs off remotes) It just depends.
</font><font color="blue" class="small">( If these remote hydraulics are so expensive, either dealer installed when new or aftermarket, it really is a big issue... )</font>
If you negociate remotes (parts & install) into the initial purchase you may be able to get a deal as part of the package. Otherwise going with an aftermarket/3rd party setup may save you considerable coin. I've spent around $350 or $400 on a 3 spool valve and fittings adding remotes to my B2910. The same setup using Kubota parts would have probably cost 3x that amount for the parts alone at full ticket.
Yup.
