Price Check Price check!
/ Price check! #1
mightymik
I found a Case385.I have no idea what hp. nor what it is worth.Thought someone might could help me out?The tractor has 2700 hrs.I have not seen the tractor in person,just pictures.The dealer is asking $5900.Thanks for any imput.
/ Price check! #2
It is a 35 pto hp machine. The price you said is in line with a 2wd machine. If it has FWA and is in great shape then it is a very good price. Either way I would offer them a few hundred less as money in your pocket is better then someone elses.
/ Price check! #3
The tractor weighs about 5000 pounds so it is good for ground engaging implements. It does for me what my 48 hp John Deere did. I think you will be impressed with it. Check the parking brake. It is a band inside the transmission and if the tractor is run much with it engaged it will shred the band and get the chunks in the hydraulic system. If it can't be adjusted the top has to come off the transmission to repair. The price is good if there are no problems with it. It is less popular because it is the smallest HP in a frame that offers engines with hp to the 60's.
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
Anvil (A64557)
Anvil (A64557)
2013 Infiniti JX35 AWD SUV (A64557)
2013 Infiniti JX35...
2006 Mack CXN613 T/A Gardner Denver Kill Truck (A64194)
2006 Mack CXN613...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
