Price Check price check on jd2320 with 62" mmm, BH, and FEL
   / price check on jd2320 with 62" mmm, BH, and FEL #1
HammA5690
Upstate , NY
Jd 2520
Just a price check on a jd 2320 with a 62" mmm, BH, and a BH. I live in upstate ny about 20 miles from binghamton. Also can the 2320 run full size implements like a brush hog or post hole auger or would I need to buy smaller implements. The tractor will be used for mowing 2 acres weekly and 5 additional about once a month, skidding logs for a wood stove and occasional digging and carrying soil and rocks in the FEL.
Any help would be great.
   / price check on jd2320 with 62" mmm, BH, and FEL #2
The 2320 has a standard Cat 1, 3 point hitch. Can't help with the price but I use a 3 point post hole digger quite a bit; no problems (until I run into large chunks of basalt). If you can swing it get one with down force. I have used both a 5 foot and 4 foot Brush Hog squealer. My place was too rough for the five footer but the four foot works fine. If your land is relatively smooth the 5 foot should work okay but in heavy stuff you may have to either overlap your passes or slow down a bit.
   / price check on jd2320 with 62" mmm, BH, and FEL #3
What is your definition of "full size implements"???
My father in law has a 81" brush hog and finish mower along with a john deere post hole digger not sure what size.
   / price check on jd2320 with 62" mmm, BH, and FEL #5
No way will you be able to run that 81" bush hog. Probably 48" max...
Oh well, I guess that's the benefit of having him live only a few minutes away. He can just drive the tractor over.
   / price check on jd2320 with 62" mmm, BH, and FEL #8
it will run the 81 inch bush hog as long as you not trying to cut a foot of grass at a time.or run over anything.it will run logspliters tillers. blades .sub soilers. snownlowers
Kubota L2501 (A50120)
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
UNUSED JCT SKID STEER QUICK ATTACH SNOW PUSHER (A51244)
UNUSED JCT SKID...
Kubota BX2380 (A50120)
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2019 JOHN DEERE XUV855M GATOR (A51243)
2019 JOHN DEERE...
